Datasheet ADL5336 (Analog Devices) - 9
DescriptionCascadable IF VGAs with Programmable RMS Detectors
Pages / Page30 / 9 — Data Sheet. ADL5336. d (. R (. E GA. LTA. –40°C. +25°C. –10. +85°C. –15. …
RevisionC
Data Sheet. ADL5336. d (. R (. E GA. LTA. –40°C. +25°C. –10. +85°C. –15. 100. 200. 300. 400. 500. 600. 700. 800. 900 1000. GAIN1 (mV). GAIN CODE 11. GAIN CODE 00
Data Sheet ADL5336 d ( R ( E GA LTA –40°C +25°C –10 +85°C –15 100 200 300 400 500 600 700 800 900 1000 GAIN1 (mV) GAIN CODE 11 GAIN CODE 00
Data Sheet ADL5336 20 4 25 4 15 3 3 20 2 10 2 ) ) 15 B B d ( (d 1 B) IN 5 1 B) d IN 10 d ( R ( GA 0 R E GA O G 0 0 GE RO RR 5 R E LTA E LTA –1 O VO V –5 –1 0 –40°C –2 –40°C +25°C +25°C –10 +85°C –2 –5 +85°C –40°C –3 –40°C +25°C +25°C +85°C +85°C –15 –3 –10 –4 0 100 200 300 400 500 600 700 800 900 1000
1 1 14 0
0
GAIN1 (mV) GAIN1 (mV)
09550- 09550- Figure 11. Gain Conformance over Temperature for VGA1 Figure 14. Gain Conformance over Temperature for VGA2
35 28 40 30 GAIN CODE 11 GAIN CODE 00 30 23 35 25 30 20 25 18 ) ) Ω 00Ω ) 25 15 ) 20 13 V 100 V e: 2 B e: B r d r d m 20 m 10 B 3 ( B 3 ( 15 8 d OIP 3 ( OIP 15 5 IP3 (d IP O O 10 3 10 0 5 –2 5 –5 GAIN CODE 11 GAIN CODE 00 0 –7 0 –10 0 100 200 300 400 500 600 700 800 900 1000
14
-1 017 0- 50
GAIN1 (mV) GAIN2 (mV)
955 095 0 Figure 12. OIP3 vs. VGAIN over Gain Code for VGA1 Figure 15. OIP3 vs. VGAIN over Gain Code for VGA2
30 23 40 30 35 25 25 18 30 20 ) ) 20 13 00Ω 25 15 200 ) ) V V re: B e: 1 d B r d 15 m 8 m 20 10 B 3 ( B 3 ( d P 3 ( OIP 3 (d OI 15 P 5 10 3 OIP OI 10 0 5 –2 5 –5 0 –7 0 –10 4.5 4.6 4.7 4.8 4.9 5.0 5.1 5.2 5.3 5.4 5.5
5
8 -01 01
VPOS (V)
550
VPOS (V)
09 9550- 0 Figure 13. OIP3 vs. Supply Voltage at VGAIN = 0.5 V for VGA1 Figure 16. OIP3 vs. Supply Voltage at VGAIN = 0.5 V for VGA2 Rev. C | Page 9 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT DESCRIPTION GAIN CONTROL INTERFACE INPUT AND OUTPUT IMPEDANCES AGC OPERATION REGISTER MAP AND CODES APPLICATIONS INFORMATION BASIC CONNECTIONS SUPPLY DECOUPLING INPUT SIGNAL PATH OUTPUT SIGNAL PATH DETECTOR OUTPUT AND GAIN PIN COMMON-MODE BYPASSING SERIAL PORT CONNECTIONS MODE AND ENABLE CONNECTIONS ERROR VECTOR MAGNITUDE (EVM) EFFECT OF CAGC ON EVM AGC INSENSITIVITY TO MODULATION TYPE EFFECT OF SETPOINT ON EVM CASCADED VGA/AGC PERFORMANCE EVALUATION BOARD LAYOUT BILL OF MATERIALS (BOM) EVALUATION BOARD CONTROL SOFTWARE OUTLINE DIMENSIONS ORDERING GUIDE
