Datasheet RH1009 (Analog Devices)
DescriptionRadiation Hardened 2.5V Reference
Pages / Page4 / 1 — DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. BURN-IN CIRCUIT. PACKAGE/ORDER …
RevisionD
File Format / SizePDF / 329 Kb
DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. BURN-IN CIRCUIT. PACKAGE/ORDER INFORMATION
Datasheet RH1009 Analog Devices, Revision: D
RH1009 2.5V Reference
DESCRIPTION ABSOLUTE MAXIMUM RATINGS
The RH®1009 is a general purpose 2.5V shunt regulator Reverse Breakdown Current ... 20mA diode designed to operate over a wide current range while Forward Current ... 10mA maintaining good stability with time and temperature. The Operating Temperature Range ... –55°C to 125°C adjust terminal allows either temperature coefficient to be Storage Temperature Range ..–65°C to 150°C minimized or the reference voltage to be adjusted without Lead Temperature (Soldering, 10 sec) ...300°C changing the temperature coefficient. Because it operates Junction Temperature ..150˚C as a shunt regulator it can be used equally well as a posi- All registered trademarks and trademarks are the property of their respective owners. Protected tive or negative reference. by U.S. patents, including XXXXX, XXXXX. The wafer lots are processed to Analog Devices’ in-house Class S flow to yield circuits usable in stringent military applications.
BURN-IN CIRCUIT PACKAGE/ORDER INFORMATION
20V BOTTOM VIEW + 2k – ADJ NC H PACKAGE RH1009 BI 3-LEAD TO-46 METAL CAN TOP VIEW NC 1 10 NC NC 2 9 NC NC 3 8 V+ V– 4 7 ADJ NC 5 6 NC W PACKAGE 10-LEAD CERPAC I.D.No.66-10-0174 Rev. D Document Feedback For more information www.analog.com 1 Document Outline Description Burn-In Circuit Absolute Maximum Ratings Package/Order Information Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Total Dose Bias Circuit Table 2: Electrical Test Requirements Revision History Typical Performance Characteristics
