Datasheet NCD2400M (IXYS)
ManufacturerIXYS
DescriptionWide Capacitance Range, Non-volatileDigital Programmable Capacitor
Pages / Page22 / 1 — NCD2400M. Wide Capacitance Range, Non-volatile. Digital Programmable …
File Format / SizePDF / 414 Kb
NCD2400M. Wide Capacitance Range, Non-volatile. Digital Programmable Capacitor. Features. Description. Applications
Datasheet NCD2400M IXYS
NCD2400M Wide Capacitance Range, Non-volatile
I
NTEGRATED CIRCUITS DIVISION
Features Description
DC to 150MHz frequency range The NCD2400M is a dedicated electronic calibrator for
512-state digital programmable capacitor oscillators, with reliable performance at 105ºC as
Series or shunt configuration required by OCXO applications. Cshunt = 12.5pF to 194pF (15.5:1 tuning ratio) in This product can be used in series or shunt discrete 355fF steps configuration to support a wide variety of tuning circuit Cseries = 1.7pF to 194pF in discrete 376fF steps topologies.
2-wire (I2C Fast-mode compatible) serial interface Digitally controlled capacitance trimming information is
EEPROM non-volatile memory
Wide power supply range (2.5V to 5.5V) communicated via a 2-wire, I2C Fast-mode compatible
Operation ambient temperature to 105ºC interface. The preferred power-up default capacitance
2 x 2 x 0.65 mm 6-pin DFN package value can be stored in the internal, re-programmable, non-volatile memory.
Applications Ordering Information
OCXOs
Part # Description
Tunable RF stages Standard product, Chip ID = 0x60,
Filter tuning NCD2400MTR DFN-6 in Tape & Reel (3000/Reel)
Capacitive sensor trimming Special order, Contact Factory for details,
Measurement equipment NCD2400M1TR Chip ID = 0x61, DFN-6 in Tape & Reel (3000/Reel)
Figure 1. NCD2400M Block Diagram
VDD V+ V+
NCD2400M
CP SDA DIGITAL INTERFACE C V+ 0 AND MEMORY SCL CN GND DS-NCD2400M-R01
www.ixysic.com
1 Document Outline Features Applications Description 1. Specifications 1.1 Package Pinout 1.2 Pin Descriptions 1.3 Absolute Maximum Ratings 1.4 Recommended Operating Conditions 1.5 ESD Rating 1.6 General Conditions for Electrical Characteristics 1.7 Capacitor Electrical Characteristics 1.8 Digital Interface: Electrical Characteristics of SDA and SCL 1.9 Digital Interface: AC Characteristics 1.10 Power Supply 2. Performance Data 3. Functional Description 3.1 Introduction 3.2 Capacitive Digital to Analog Converter (CDAC) 3.3 Non-Volatile Memory Configuration 3.4 Device Address 3.5 Operating Modes 3.5.1 Volatile Mode 3.5.2 Non-Volatile Mode 3.6 I2C Serial Interface 3.6.1 Write Commands 3.6.2 Write Volatile Register Operation 3.6.3 Write Non-Volatile Memory Operation 3.6.4 Read Operation 3.6.5 Set Non-Volatile Mode Operation 3.6.6 Electrical and Timing Considerations 3.6.7 Application Diagrams 3.7 Capacitor Interface Electrical and Biasing Considerations 4. Capacitance Determination and Programming Procedure 5. Manufacturing Information 5.1 Moisture Sensitivity 5.2 ESD Sensitivity 5.3 Soldering Profile 5.4 Board Wash 5.5 Mechanical Dimensions 5.5.1 Package Dimensions 5.5.2 Tape & Reel Specification
