Datasheet BC3602 (Holtek) - 5
ManufacturerHoltek
DescriptionSub-1GHz Low RX Current FSK/GFSK RF Transceiver
Pages / Page61 / 5 — BC3602. A.C. Characteristics. Symbol. Parameter. Test Conditions. Min. …
BC3602. A.C. Characteristics. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit. RF Characteristics. Transmitter. Receiver
BC3602 A.C Characteristics Symbol Parameter Test Conditions Min Typ Max Unit RF Characteristics Transmitter Receiver
BC3602 A.C. Characteristics
Ta=25°C, VDD=3.3V, fXTAL=16MHz, FSK modulation with matching circuit and low/high pass filter, RF output is powered by VDD (3.3V), unless otherwise specified.
Symbol Parameter Test Conditions Min. Typ. Max. Unit RF Characteristics
315MHz band — 315 — 433MHz band — 433.92 — fRF RF Frequency Band 470~510MHz band — 490 — MHz 868MHz band — 868.3 — 915MHz band — 915 — DR Data Rate GFSK modulation 2 ─ 250 Kbps
Transmitter
433MHz band 0 — 13 POUT TX Output Power dBm 868MHz band 0 — 13 f < 1GHz — — -36 47MHz<f<74MHz 87.5MHz<f<118MHz S.E.TX TX Spurious Emission (POUT=10dBm) — — -54 dBm 174MHz<f<230MHz 470MHz<f<862MHz 2nd, 3rd Harmonic — — -30
Receiver
tST,RX RX Settling Time Light Sleep mode to RX mode — 150 — μs 2Kbps (fDEV=8kHz) — -120 — 10Kbps (fDEV=40kHz) — -114 — 315MHz RX Sensitivity @ BER=0.1% 50Kbps (fDEV=18.75kHz) — -110 — dBm 125Kbps (fDEV=46.875kHz) — -106 — 250Kbps (fDEV=93.75kHz) — -103 — 2Kbps (fDEV=8kHz) — -120 — 10Kbps (fDEV=40kHz) — -113 — 433MHz RX Sensitivity @ BER=0.1% 50Kbps (fDEV=18.75kHz) — -110 — dBm 125Kbps (fDEV=46.875kHz) — -106 — 250Kbps (f P DEV=93.75kHz) — -103 — Sens 2Kbps (fDEV=8kHz) — -119 — 10Kbps (fDEV=40kHz) — -113 — 868MHz RX Sensitivity @ BER=0.1% 50Kbps (fDEV=18.75kHz) — -109 — dBm 125Kbps (fDEV=46.875kHz) — -106 — 250Kbps (fDEV=93.75kHz) — -103 — 2Kbps (fDEV=8kHz) — -119 — 10Kbps (fDEV=40kHz) — -113 — 915MHz RX Sensitivity @ BER=0.1% 50Kbps (fDEV=18.75kHz) — -109 — dBm 125Kbps (fDEV=46.875kHz) — -106 — 250Kbps (fDEV=93.75kHz) — -103 — PIN,max Maxmum Input Power @ BER<0.1% — — 10 dBm IR Image Rejection — — 25 — dB 25MHz~1GHz — — -57 S.E.RX RX Spurious dBm Above 1GHz — — -47 RSSI Range AGC on -110 — -10 dBm Rev. 1.00 5 July 29, 2019 Document Outline Features General Description Block Diagram Pin Assignment Pin Description Absolute Maximum Ratings D.C. Characteristics A.C. Characteristics Memory Mapping Control Register Access SFR Mapping and Bit Definition Common Area Control Register Bank 0 Control Registers Bank 1 Control Registers Bank 2 Control Registers Special Function Description Sub-1GHz RF Transceiver Serial Interface System Clock Frequency Synthesizer Modulator State Machine Calibration AGC & RSSI Packet Handler FIFO Operation Modes Receiving Packet Judgement Continuous RX Mode ARK Mode: Auto-Resend and Auto-Ack ATR Mode: Auto-Transmit-Receive Message Flowchart Examples Abbreviation Application Circuits Package Information SAW Type 24-pin QFN (3mm×3mm×0.55mm) Outline Dimensions
