Datasheet LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302 (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionSingle Supply Quad Comparators
Pages / Page11 / 3 — LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302. …
Revision25
File Format / SizePDF / 165 Kb
LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302. ELECTRICAL CHARACTERISTICS. LM2901/2901E/2901V
LM339, LM339E, LM239, LM2901, LM2901E, LM2901V, NCV2901, MC3302 ELECTRICAL CHARACTERISTICS LM2901/2901E/2901V
link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3
(VCC = +5.0 Vdc, TA = +25°C, unless otherwise noted)
LM2901/2901E/2901V LM239/339/339E /NCV2901 MC3302 Characteristic Symbol Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage (Note 3) VIO − ±2.0 ±5.0 − ±2.0 ±7.0 − ±3.0 ±20 mVdc Input Bias Current (Notes 3, 4) IIB − 25 250 − 25 250 − 25 500 nA (Output in Analog Range) Input Offset Current (Note 3) IIO − ±5.0 ±50 − ±5.0 ±50 − ±3.0 ±100 nA Input Common Mode Voltage Range VICMR 0 − VCC 0 − VCC 0 − VCC V (Note 5) −1.5 −1.5 −1.5 Supply Current ICC mA RL = ∞ (For All Comparators) − 0.8 2.0 − 0.8 2.0 − 0.8 2.0 RL = ∞, VCC = 30 Vdc − 1.0 2.5 − 1.0 2.5 − 1.0 2.5 Voltage Gain AVOL 50 200 − 25 100 − 25 100 − V/mV RL ≥ 15 kW, VCC = 15 Vdc Large Signal Response Time − − 300 − − 300 − − 300 − ns VI = TTL Logic Swing, Vref = 1.4 Vdc, VRL = 5.0 Vdc, RL = 5.1 kW Response Time (Note 6) − − 1.3 − − 1.3 − − 1.3 − ms VRL = 5.0 Vdc, RL = 5.1 kW Output Sink Current ISink 6.0 16 − 6.0 16 − 6.0 16 − mA VI (−) ≥ +1.0 Vdc, VI(+) = 0, VO ≤ 1.5 Vdc Saturation Voltage Vsat − 130 400 − 130 400 − 130 500 mV VI(−) ≥ +1.0 Vdc, VI(+) = 0, Isink ≤ 4.0 mA Output Leakage Current IOL − 0.1 − − 0.1 − − 0.1 − nA VI(+) ≥ +1.0 Vdc, VI(−) = 0, VO = +5.0 Vdc Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 2. (LM239) Tlow = −25°C, Thigh = +85° (LM339, LM339E) Tlow = 0°C, Thigh = +70°C (MC3302) Tlow = −40°C, Thigh = +85°C (LM2901), LM2901E Tlow = −40°C, Thigh = +105° (LM2901V & NCV2901) Tlow = −40°C, Thigh = +125°C NCV2901 is qualified for automotive use. 3. At the output switch point, VO ] 1.4 Vdc, RS ≤ 100 W 5.0 Vdc ≤ VCC ≤ 30 Vdc, with the inputs over the full common mode range (0 Vdc to VCC −1.5 Vdc). 4. The bias current flows out of the inputs due to the PNP input stage. This current is virtually constant, independent of the output state. 5. Positive excursions of input voltage may exceed the power supply level. As long as one input voltage remains within the common mode range, the comparator will provide a proper output state. Refer to the Maximum Ratings table for safe operating area. 6. The response time specified is for a 100 mV input step with 5.0 mV overdrive. For larger signals, 300 ns is typical.
www.onsemi.com 3
