VCNL3040 www.vishay.com Vishay Semiconductors Proximity Sensor With Interrupt, IRED, and I2C InterfaceFEATURES • Package type: surface-mount • Dimensions (L x W x H in mm): 4.0 x 2.0 x 1.1 • Integrated modules: infrared emitter (IRED), proximity sensor (PS), and signal conditioning IC • Temperature compensation: -40 °C to +85 °C • Low power consumption I2C (SMBus compatible) interface • Floor life: 168 h, MSL 3, according to DESIGN SUPPORT TOOLS AVAILABLE J-STD-020 • Output type: I2C bus (PS) D 33 D • Operation voltage: 2.5 V to 3.6 V 3D Models Design Tools Related Documents • Material categorization: for definitions of compliance DESCRIPTION please see www.vishay.com/doc?99912 VCNL3040 integrates a proximity sensor (PS), and a high PROXIMITY FUNCTION power IRED into one small package. It incorporates photodiodes, amplifiers, and analog to digital converting • Immunity to red glow (940 nm IRED) circuits into a single chip by CMOS process. PS • Programmable IRED sink current programmable interrupt features of individual high and low • Intelligent cancellation to reduce cross talk thresholds offers the best utilization of resource and power • Smart persistence scheme to reduce PS response time saving on the microcontroller. • Selectable for 12-bit / 16-bit PS output data The 12-bit / 16-bit proximity sensing function uses on intelligent cancellation scheme, so that cross talk INTERRUPT phenomenon is eliminated effectively. To accelerate the PS response time, smart persistence prevents the misjudgment • Programmable interrupt function for PS with upper and of proximity sensing but also keeps a fast response time. lower thresholds Active force mode, one time trigger by one instruction, is • Adjustable persistence to prevent false triggers for PS another good approach for more design flexibility to fulfill different kinds of applications with more power saving. APPLICATIONS The VCNL3040 provides an excellent temperature • Handheld device compensation capability for keeping output stable under • Consumer device various temperature configurations. PS functions are easily operated via the simple command format of I2C (SMBus • Industrial application compatible) interface protocol. Operating voltage ranges from 2.5 V to 3.6 V. VCNL3040 is packaged in a lead (Pb)-free 8 pin QFN package, which offers the best market-proven reliability quality. PRODUCT SUMMARYOPERATINGOPERATINGI2C BUSIRED PULSEADC RESOLUTIONPARTOUTPUTRANGEVOLTAGE RANGEVOLTAGE RANGECURRENTPROXIMITY /NUMBERCODE(mm)(V)(V)(mA)AMBIENT LIGHT VCNL3040 0 to 300 2.5 to 3.6 1.8 to 3.6 200 12 bit / 16-bit, I2C 16 bit / n/a ORDERING INFORMATION ORDERING CODEPACKAGINGVOLUME (1)PIN NUMBERREMARKS VCNL3040 Tape and reel MOQ: 2500 pcs 8 4.0 mm x 2.0 mm x 1.1 mm Note (1) MOQ: minimum order quantity Rev. 1.2, 08-Jul-2019 1 Document Number: 84917 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
