Datasheet VCNL3040 (Vishay) - 3
ManufacturerVishay
DescriptionProximity Sensor With Interrupt, IRED, and I²C Interface
Pages / Page17 / 3 — VCNL3040. BLOCK DIAGRAM. BASIC CHARACTERISTICS. PARAMETER. TEST …
File Format / SizePDF / 258 Kb
VCNL3040. BLOCK DIAGRAM. BASIC CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. Note
VCNL3040 BLOCK DIAGRAM BASIC CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT Note
VCNL3040
BLOCK DIAGRAM
V Anode DD PS timing controller PD buffer DSP PS IRED PD Oscilator LED_CATHODE LED driver Temperature sensor INT I2C bus logic SCLK control SDAT GND
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage VDD 2.5 - 3.6 V Supply current Excluded LED driving, VDD = 2.28 V IDD - 300 - μA Shutdown current Light condition = dark, VDD = 3.3 V IDD (SD) 0.01 0.2 1 μA I2C supply voltage Vpull_up 1.8 - 3.6 V Logic high VIH 1.55 - - VDD = 3.3 V V Logic low VIL - - 0.4 I2C signal input Logic high VIH 1.4 - - VDD = 2.6 V V Logic low VIL - - 0.4 Peak sensitivity wavelength of PS λpps - 850 - nm Full PS counts 12-bit / 16-bit resolution - - 4096 / 65 535 steps V PS dark offset DD/VLED = 2.8 V, PS_IT = 1T, 0 - 3 steps IRED current = 100 mA, dark room PS detection range Kodak gray card 0 - 300 mm Operating temperature range Tamb -40 - +85 °C IRED driving current (1) - - 200 mA
Note
(1) Programmable between 50 mA and 200 mA Rev. 1.2, 08-Jul-2019
3
Document Number: 84917 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
