Datasheet VCNL3040 (Vishay) - 2
ManufacturerVishay
DescriptionProximity Sensor With Interrupt, IRED, and I²C Interface
Pages / Page17 / 2 — VCNL3040. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 258 Kb
VCNL3040. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. MIN. MAX. UNIT. RECOMMENDED OPERATING CONDITIONS. PIN DEFINITION
VCNL3040 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL MIN MAX UNIT RECOMMENDED OPERATING CONDITIONS PIN DEFINITION
VCNL3040
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 2.5 3.6 V Operation temperature range Tamb -40 +85 °C Storage temperature range Tstg -40 +100 °C
Supply voltage VDD 2.5 3.6 V Operation temperature range Tamb -40 +85 °C I2C bus operating frequency f(I2CCLK) 10 400 kHz
PIN DEFINITION
8 5 1 Top View 4
PIN DESCRIPTIONS PIN ASSIGNMENT SYMBOL TYPE FUNCTION
1 VDD I Power supply input 2 NC - No connection 3 GND I Ground 4 CATHODE I IRED cathode connection 5 ANODE I Anode for IRED 6 SCLK I I2C digital bus clock input 7 INT O Interrupt pin 8 SDAT I / O (open drain) I2C data bus data input / output Rev. 1.2, 08-Jul-2019
2
Document Number: 84917 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
