AOZ6683CIEZBuckTM 3A Synchronous Buck RegulatorGeneral DescriptionFeatures The AOZ6683CI is a high efficiency, easy to use, 3A 4.5V to 18V operating input voltage range synchronous buck regulator at high switching frequency Synchronous Buck: 110mΩ internal high-side switch for small form factor solution. The AOZ6683CI works and 55mΩ internal low-side switch from 4.5V to 18V input voltage range, and provides up to Up to 95% efficiency 3A of continuous output current with an output voltage adjustable down to 0.8V. Pulse energy mode for high light load efficiency (Vin=12V, Vo=5V, 89% @10mA) The AOZ6683CI comes in an ultra thin TSOT23-6L Output voltage adjustable to 0.8V package and is rated from -40°C to +125°C junction 3A continuous output current temperature range. 750kHz PWM operation Internal compensation Internal Soft Start Cycle-by-cycle current limit Pre-bias start-up Short-circuit protection Thermal shutdown Ultra-thin TSOT23-6L package Applications General Point of Load LCD TV Cable modems and Gateway Typical Application VIN VIN BST 4.5V ~ 18V CIN CBST L1 AOZ6683CI LX VOUT EN EN R R T 1 FB GND CO R2 Figure 1. 3A Synchronous Buck Regulator Rev. 2.0 January 2019 www.aosmd.com Page 1 of 15
