Datasheet AD8216 (Analog Devices) - 6
DescriptionHigh Bandwidth, Bidirectional 65 V Difference Amplifier
Pages / Page16 / 6 — AD8216. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 500. 400. 300. …
RevisionC
File Format / SizePDF / 351 Kb
AD8216. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 500. 400. 300. 200. –10. 100. –15. –20. N (. –25. –100. –30. –200. –35. –40. –300. –45. –50. –400. –55. –500
AD8216 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 500 400 300 200 –10 100 –15 –20 N ( –25 –100 –30 –200 –35 –40 –300 –45 –50 –400 –55 –500
AD8216 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 500 20 15 400 10 300 5 0 200 –5 –10 100 V) B) –15 d 0 –20 SI N ( O AI V –25 –100 G –30 –200 –35 –40 –300 –45 –50 –400 –55 –500 –60 –40 –20 0 20 40 60 80 100 120
016
10k 100k 1M 10M
015
TEMPERATURE (°C) FREQUENCY (Hz)
07062- 07062- Figure 4. Typical Offset Drift Figure 7. Typical Small Signal Bandwidth (VOUT = 200 mV p-p)
120 110 INPUT (200mV/DIV) 100 90 80 B) 70 d 60 RR ( OUTPUT (500mV/DIV) 50 CM 40 30 20 10 0 10 100 1k 10k 100k 1M 10M 100M
021 011
FREQUENCY (Hz) TIME (200ns/DIV)
07062- 07062- Figure 5. CMRR vs. Frequency Figure 8. Rise Time
1500 1300 1100 900 700 m) 500 p INPUT (200mV/DIV) p 300 R ( 100 RRO –100 –300 N E AI –500 G –700 –900 OUTPUT (500mV/DIV) –1100 –1300 –1500 –40 –20 0 20 40 60 80 100 120
017 010
TEMPERATURE (°C) TIME (200ns/DIV)
07062- 07062- Figure 6. Typical Gain Drift Figure 9. Fall Time Rev. C | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
