Datasheet AD8216 (Analog Devices) - 7
DescriptionHigh Bandwidth, Bidirectional 65 V Difference Amplifier
Pages / Page16 / 7 — Data Sheet. AD8216. m ( NT RE. INPUT (1V/DIV). CUR CE. UR O S T U P. T U …
RevisionC
File Format / SizePDF / 351 Kb
Data Sheet. AD8216. m ( NT RE. INPUT (1V/DIV). CUR CE. UR O S T U P. T U O. OUTPUT (2V/DIV). IM AX M. –40. –20. 100. 120. 140. TIME (500ns/DIV)
Data Sheet AD8216 m ( NT RE INPUT (1V/DIV) CUR CE UR O S T U P T U O OUTPUT (2V/DIV) IM AX M –40 –20 100 120 140 TIME (500ns/DIV)
Data Sheet AD8216 A) 10 m ( NT RE 8 INPUT (1V/DIV) CUR CE 6 UR O S T U P 4 T U O UM 2 OUTPUT (2V/DIV) IM AX M 0
9 8
–40 –20 0 20 40 60 80 100 120 140
01 00 2- 2- 06
TIME (500ns/DIV)
06
TEMPERATURE (°C)
07 07 Figure 10. Differential Overload Recovery (Falling) Figure 13. Maximum Output Source Current vs. Temperature
5.0 4.5 ) V ( E INPUT (1V/DIV) 4.0 RANG E AG 3.5 T L O V 3.0 UT P UT O OUTPUT (2V/DIV) 2.5 2.0
9 7 00
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
00 2- 2-
TIME (500ns/DIV)
06
OUTPUT SOURCE CURRENT (mA)
06 07 07 Figure 11. Differential Overload Recovery (Rising) Figure 14. Output Voltage Range vs. Output Source Current
8 2.5 ) V A) 7 m ( ND ( 2.0 G NT 6 M RE RO F 5 E 1.5 NG INK CUR 4 S RA E UT P 1.0 3 AG UT T L O O M 2 V U IM UT 0.5 P AX 1 UT M O 0 0
0 6
02
00 2- 2- 06
TEMPERATURE (°C)
06
OUTPUT SINK CURRENT (mA)
07 07 Figure 12. Maximum Output Sink Current vs. Temperature Figure 15. Output Voltage Range from GND vs. Output Sink Current Rev. C | Page 7 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
