OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator The device is designed for the harsh environment of automotive applications. Therefore standard features like output current limitation and overtemperature shutdown are implemented and protect the device against failures like output short circuit to GND, over-current and over-temperature. The TLS715B0NAV50 can be also used in all other applications requiring a stabilized 5 V supply voltage. TypePackageMarking TLS715B0NAV50 PG-TSNP-7 715B5 Datasheet 2 Rev. 1.1 2019-07-31 Document Outline Features Potential applications Product validation Description Table of contents 1 Block diagram 2 Pin configuration 2.1 Pin assignment PG-TSNP-7 2.2 Pin definitions and functions PG-TSNP-7 3 General product characteristics 3.1 Absolute maximum ratings 3.2 Functional range 3.3 Thermal resistance 4 Block description and electrical characteristics 4.1 Voltage regulation 4.2 Typical performance characteristics voltage regulator 4.3 Current consumption 4.4 Typical performance characteristics current consumption 4.5 Enable 4.6 Typical performance characteristics enable 5 Application information 5.1 Application diagram 5.2 Selection of external components 5.2.1 Input pin 5.2.2 Output pin 5.3 Thermal considerations 5.4 Reverse polarity protection 5.5 Further application information 6 Package information 7 Revision history
