Datasheet PT7C4363BQ (Diodes) - 4
Manufacturer | Diodes |
Description | Automotive Real Time Clock |
Pages / Page | 23 / 4 — PT7C4363BQ. Maximum Ratings. Note:. Recommended Operating Conditions. … |
File Format / Size | PDF / 911 Kb |
PT7C4363BQ. Maximum Ratings. Note:. Recommended Operating Conditions. Symbol. Description. Min. Typ. Max. Unit
PT7C4363BQ Maximum Ratings
Storage Temperature ... -65oCto +150oC Junction Temperature .. +125oC Max Supply Voltage to Ground Potential (Vcc to GND) .. -0.3V to +6.5V DC Input (All Other Inputs except Vcc & GND) ... -0.3V to (Vcc+0.3V) DC Output Voltage (SDA, /INTA, /INTB pins) .. -0.3V to +6.5V Power Dissipation .. 320mW
Note:
Stresses greater than those listed under MAXIMUM RATINGS may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability.
Recommended Operating Conditions Symbol Description Min. Typ. Max. Unit
VCC Power voltage 1.3 - 5.5 VIH Input high level 0.7 VCC - VCC+0.3 V VIL Input low level -0.3 - 0.3 VCC TA Operating temperature -40 - 85 ºC
DC Electrical Characteristics
Unless otherwise specified, GND =0V, VCC = 1.3 ~ 5.5 V, TA = -40 °C to +125 °C, fOSC = 32.768kHz.
Sym. Description Pin Conditions Min. Typ. Max. Unit
Interface inactive. T Supply voltage V A = 25°C 1) 1.1 - 5.5 CC Interface active. f V SCL = 400kHz , TA = 25°C 1) 1.3 - 5.5 CC V Supply voltage for clock V data integrity CC - 1.1 - 5.5 f I SCL = 400kHz - - 35 CCA Active Supply current VCC Interface active µA fSCL = 100kHz - - 15 Interface inactive (fSCL = 0Hz), VCC = 5.0V - 450 1300 pin 7 disabled 2) nA V T CC = 3.0V - 400 1000 I A=-40~125°C CCS Standby current VCC Interface inactive (fSCL = 0Hz), VCC = 5.0V - 650 1500 pin 7 enabled at 32kHz 2) nA V T CC = 3.0V - 600 1200 A=-40~125°C VIL1 Low-level input voltage SCL - 0 - 0.3VCC V VIH1 High-level input voltage SCL - 0.7VCC - VCC SDA V I OL = 0.4V, VCC = 5V -3 - - OL Low-level output voltage mA /INT, SQW VOL = 0.4V, VCC = 5V -1 - - IIL Input leakage current SCL - -1 - 1 µA IOZ Output current when OFF - - -1 - 1 µA Note: 1) For reliable oscillator start-up at power-up: VCC(min)power-up = VCC(min) + 0.3 V. 2) Timer source clock = 1/60 Hz, voltage of SCL and SDA is VCC or GND. PT7C4363BQ
www.diodes.com
July 2019 Document Number DS42042 Rev 1-2 4 © Diodes Incorporated Document Outline Features Description Pin Configuration Pin Description Function Block Maximum Ratings Recommended Operating Conditions DC Electrical Characteristics AC Electrical Characteristics Recommended Layout for Crystal Cpar is all parasitical capacitor between X1 and X2. Crystal Specifications Function Description Overview of Functions Registers Control and Status Register Time Counter Days of the Week Counter Calendar Counter AE W4 Communication I2C Bus Interface Overview of I2C-BUS System Configuration Starting and Stopping I2C Bus Communications Slave Address Part Marking Mechanical Information
