Datasheet IR3888 OptiMOS IPOL (Infineon) - 8
ManufacturerInfineon
Description25 A single-voltage synchronous Buck regulator
Pages / Page49 / 8 — IR 888 OptiMOS™ IPOL. 25 A single-voltage synchronous Buck regulator. Pin …
Revision01_00
File Format / SizePDF / 2.7 Mb
IR 888 OptiMOS™ IPOL. 25 A single-voltage synchronous Buck regulator. Pin descriptions. Pin#. Pin Name. I/O. Type. Pin Description
IR 888 OptiMOS™ IPOL 25 A single-voltage synchronous Buck regulator Pin descriptions Pin# Pin Name I/O Type Pin Description
Supply voltage for the high side driver. Connect this pin to 20 Boot I Analog the SW pin through a bootstrap capacitor. 21 EN I Analog Enable pin to turn the IC on and off. Not 22 NC - Not connected internally. They can be left floating on PCB. connected Final Datasheet 8 of 49 V2.1 2019-12-11 Document Outline Revision History Trademarks Disclaimer
