Datasheet TMP05, TMP06 (Analog Devices) - 9
Description±0.5°C Accurate PWM Temperature Sensor in 5-Lead SC-70
Pages / Page28 / 9 — Data Sheet. TMP05/TMP06. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. …
RevisionC
File Format / SizePDF / 473 Kb
Data Sheet. TMP05/TMP06. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. OUT. VDD. TMP05/. TMP06. CONV/IN. TOP VIEW. FUNC. (Not to Scale). GND
Data Sheet TMP05/TMP06 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUT VDD TMP05/ TMP06 CONV/IN TOP VIEW FUNC (Not to Scale) GND
link to page 13
Data Sheet TMP05/TMP06 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUT 1 5 VDD TMP05/ TMP06 CONV/IN 2 TOP VIEW FUNC 3 (Not to Scale) 4 GND
005 03340- Figure 5. Pin Configuration
Table 5. Pin Function Descriptions Pin No. Mnemonic Description
1 OUT Digital Output. Pulse-width modulated (PWM) output gives a square wave whose ratio of high-to-low period is proportional to temperature. 2 CONV/IN Digital Input. In continuously converting and one shot operating modes, a high, low, or float input determines the temperature measurement rate. In daisy-chain operating mode, this pin is the input pin for the PWM signal from the previous part on the daisy chain. 3 FUNC Digital Input. A high, low, or float input on this pin gives three different modes of operation. For details, see the Operating Modes section. 4 GND Analog and Digital Ground. 5 V Positive Supply Voltage, 3.0 V to 5.5 V. Using a decoupling capacitor of 0.1 µF as close as possible to this pin is DD strongly recommended. Rev. C | Page 9 of 28 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications TMP05A/TMP06A Specifications TMP05B/TMP06B Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Circuit Information Converter Details Functional Description Operating Modes Continuously Converting Mode One Shot Mode Conversion Rate Daisy-Chain Mode TMP05 Output TMP06 Output Application Hints Thermal Response Time Self-Heating Effects Supply Decoupling Layout Considerations Temperature Monitoring Daisy-Chain Application TMP05 Program Code Example 1 Continuously Converting Application TMP05 Program Code Example 2 Outline Dimensions Ordering Guide
