Datasheet EFR32MG22 (Silicon Labs) - 2
ManufacturerSilicon Labs
DescriptionWireless Gecko SoC Family
Pages / Page101 / 2 — 1. Feature List. Low Power Wireless System-on-Chip. Wide selection of MCU …
1. Feature List. Low Power Wireless System-on-Chip. Wide selection of MCU peripherals. Radio Performance
1 Feature List Low Power Wireless System-on-Chip Wide selection of MCU peripherals Radio Performance
EFR32MG22 Wireless Gecko SoC Family Data Sheet Feature List
1. Feature List
The EFR32MG22 highlighted features are listed below. •
• High Performance 32-bit 76.8 MHz MHz ARM Cortex®-M33 • 12-bit 1 Msps SAR Analog to Digital Converter (ADC) with DSP instruction and floating-point unit for efficient sig- • Up to 26 General Purpose I/O pins with output state reten- nal processing tion and asynchronous interrupts • Up to 512 kB flash program memory • 8 Channel DMA Controller • Up to 32 kB RAM data memory • 12 Channel Peripheral Reflex System (PRS) • 2.4 GHz radio operation • 4 × 16-bit Timer/Counter with 3 Compare/Capture/PWM •
Radio Performance
channels • -102.3 dBm sensitivity @ 250 kbps O-QPSK DSSS • 1 × 32-bit Timer/Counter with 3 Compare/Capture/PWM • -106.7 dBm sensitivity @ 125 kbps GFSK channels • -98.9 dBm sensitivity @ 1 Mbit/s GFSK • 32-bit Real Time Counter • -96.2 dBm sensitivity @ 2 Mbit/s GFSK • 24-bit Low Energy Timer for waveform generation • TX power up to 6 dBm • 1 × Watchdog Timer • 2.5 mA radio receive current • 2 × Universal Synchronous/Asynchronous Receiver/Trans- mitter (UART/SPI/SmartCard (ISO 7816)/IrDA/I2S) • 3.4 mA radio transmit current @ 0 dBm output power • 1 × Enhanced Universal Asynchronous Receiver/Transmit- • 7.5 mA radio transmit current @ 6 dBm output power ter (EUART) •
Low System Energy Consumption
• 2 × I2C interface with SMBus support • 3.6 mA RX current (1 Mbps GFSK) • Digital microphone interface (PDM) • 3.9 mA RX current (250 kbps O-QPSK DSSS) • Precision Low-Frequency RC Oscillator to replace 32 kHz • 4.1 mA TX current @ 0 dBm output power sleep crystal • 8.2 mA TX current @ 6 dBm output power • RFSENSE with selective OOK mode • 26 μA/MHz in Active Mode (EM0) at 38.4 MHz • Die temperature sensor with +/-1.5 degree C accuracy after • 1.40 μA EM2 DeepSleep current (32 kB RAM retention and single-point calibration RTC running from LFRCO) •
Wide Operating Range
• 0.17 μA EM4 current • 1.71 V to 3.8 V single power supply •
Supported Modulation Format
• -40 °C to 125 °C • 2 (G)FSK with fully configurable shaping •
Security Features
• OQPSK DSSS • Secure Boot with Root of Trust and Secure Loader (RTSL) • (G)MSK • Hardware Cryptographic Acceleration for AES128/256, •
Protocol Support
SHA-1, SHA-2 (up to 256-bit), ECC (up to 256-bit), ECDSA, • Bluetooth Low Energy (Bluetooth 5.2) and ECDH • Direction finding using Angle-of-Arrival (AoA) and Angle-of- • True Random Number Generator (TRNG) compliant with Departure (AoD) NIST SP800-90 and AIS-31 • Zigbee • ARM® TrustZone® • Proprietary • Secure Debug with lock/unlock •
Packages
QFN40
5 mm × 5 mm × 0.85 mm •
QFN32
4 mm × 4 mm × 0.85 mm •
TQFN32
4 mm × 4 mm × 0.30 mm
silabs.com
| Building a more connected world. Preliminary Rev. 0.5 | 2 Document Outline 1. Feature List 2. Ordering Information 3. System Overview 3.1 Introduction 3.2 Radio 3.2.1 Antenna Interface 3.2.2 Fractional-N Frequency Synthesizer 3.2.3 Receiver Architecture 3.2.4 Transmitter Architecture 3.2.5 Packet and State Trace 3.2.6 Data Buffering 3.2.7 Radio Controller (RAC) 3.2.8 RFSENSE Interface 3.3 General Purpose Input/Output (GPIO) 3.4 Clocking 3.4.1 Clock Management Unit (CMU) 3.4.2 Internal and External Oscillators 3.5 Counters/Timers and PWM 3.5.1 Timer/Counter (TIMER) 3.5.2 Low Energy Timer (LETIMER) 3.5.3 Real Time Clock with Capture (RTCC) 3.5.4 Back-Up Real Time Counter 3.5.5 Watchdog Timer (WDOG) 3.6 Communications and Other Digital Peripherals 3.6.1 Universal Synchronous/Asynchronous Receiver/Transmitter (USART) 3.6.2 Enhanced Universal Asynchronous Receiver/Transmitter (EUART) 3.6.3 Inter-Integrated Circuit Interface (I2C) 3.6.4 Peripheral Reflex System (PRS) 3.6.5 Pulse Density Modulation (PDM) Interface 3.7 Security Features 3.7.1 Secure Boot with Root of Trust and Secure Loader (RTSL) 3.7.2 Cryptographic Accelerator 3.7.3 True Random Number Generator 3.7.4 Secure Debug with Lock/Unlock 3.8 Analog 3.8.1 Analog to Digital Converter (IADC) 3.9 Power 3.9.1 Energy Management Unit (EMU) 3.9.2 Voltage Scaling 3.9.3 DC-DC Converter 3.9.4 Power Domains 3.10 Reset Management Unit (RMU) 3.11 Core and Memory 3.11.1 Processor Core 3.11.2 Memory System Controller (MSC) 3.11.3 Linked Direct Memory Access Controller (LDMA) 3.12 Memory Map 3.13 Configuration Summary 4. Electrical Specifications 4.1 Electrical Characteristics 4.2 Absolute Maximum Ratings 4.3 General Operating Conditions 4.4 DC-DC Converter 4.4.1 DC-DC Operating Limits 4.5 Thermal Characteristics 4.6 Current Consumption 4.6.1 MCU current consumption using DC-DC at 3.0 V input 4.6.2 MCU current consumption at 3.0 V 4.6.3 MCU current consumption at 1.8 V 4.6.4 Radio current consumption at 3.0V using DCDC 4.7 Flash Characteristics 4.8 Wake Up, Entry, and Exit times 4.9 RFSENSE Low-energy Wake-on-RF 4.10 2.4 GHz RF Transceiver Characteristics 4.10.1 RF Transmitter Characteristics 4.10.1.1 RF Transmitter General Characteristics for the 2.4 GHz Band 4.10.1.2 RF Transmitter Characteristics for 802.15.4 DSSS-OQPSK in the 2.4 GHz Band 4.10.1.3 RF Transmitter Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 1 Mbps Data Rate 4.10.1.4 RF Transmitter Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 2 Mbps Data Rate 4.10.1.5 RF Transmitter Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 500 kbps Data Rate 4.10.1.6 RF Transmitter Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 125 kbps Data Rate 4.10.2 RF Receiver Characteristics 4.10.2.1 RF Receiver General Characteristics for the 2.4 GHz Band 4.10.2.2 RF Receiver Characteristics for 802.15.4 DSSS-OQPSK in the 2.4 GHz Band 4.10.2.3 RF Receiver Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 1 Mbps Data Rate 4.10.2.4 RF Receiver Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 2 Mbps Data Rate 4.10.2.5 RF Receiver Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 500 kbps Data Rate 4.10.2.6 RF Receiver Characteristics for Bluetooth Low Energy in the 2.4 GHz Band 125 kbps Data Rate 4.11 Oscillators 4.11.1 High Frequency Crystal Oscillator 4.11.2 Low Frequency Crystal Oscillator 4.11.3 High Frequency RC Oscillator (HFRCO) 4.11.4 Fast Start_Up RC Oscillator (FSRCO) 4.11.5 Precision Low Frequency RC Oscillator (LFRCO) 4.11.6 Ultra Low Frequency RC Oscillator 4.12 GPIO Pins (3V GPIO pins) 4.13 Analog to Digital Converter (IADC) 4.14 Temperature Sense 4.15 Brown Out Detectors 4.15.1 DVDD BOD 4.15.2 LE DVDD BOD 4.15.3 AVDD and IOVDD BODs 4.16 PDM Timing Specifications 4.16.1 Pulse Density Modulator (PDM), Common DBUS 4.17 USART SPI Master Timing 4.17.1 SPI Master Timing, Voltage Scaling = VSCALE2 4.17.2 SPI Master Timing, Voltage Scaling = VSCALE1 4.18 USART SPI Slave Timing 4.18.1 SPI Slave Timing, Voltage Scaling = VSCALE2 4.18.2 SPI Slave Timing, Voltage Scaling = VSCALE1 4.19 I2C Electrical Specifications 4.19.1 I2C Standard-mode (Sm) 4.19.2 I2C Fast-mode (Fm) 4.19.3 I2C Fast-mode Plus (Fm+) 4.20 Typical Performance Curves 4.20.1 Supply Current 4.20.2 RF Characteristics 4.20.3 DC-DC Converter 5. Typical Connections 5.1 Power 5.2 RF Matching Networks 5.2.1 2.4 GHz Matching Network 5.3 Other Connections 6. Pin Definitions 6.1 QFN40 Device Pinout 6.2 TQFN32 Device Pinout 6.3 QFN32 Device Pinout 6.4 Alternate Function Table 6.5 Analog Peripheral Connectivity 6.6 Digital Peripheral Connectivity 7. QFN32 Package Specifications 7.1 QFN32 Package Dimensions 7.2 QFN32 PCB Land Pattern 7.3 QFN32 Package Marking 8. TQFN32 Package Specifications 8.1 TQFN32 Package Dimensions 8.2 TQFN32 PCB Land Pattern 8.3 TQFN32 Package Marking 9. QFN40 Package Specifications 9.1 QFN40 Package Dimensions 9.2 QFN40 PCB Land Pattern 9.3 QFN40 Package Marking 10. Revision History
