Datasheet ISM330DHCX (STMicroelectronics) - 4
Manufacturer | STMicroelectronics |
Description | iNEMO inertial module with Machine Learning Core |
Pages / Page | 167 / 4 — ISM330DHCX. Embedded low-power features. DS13012. Rev 5. page 4/167 |
File Format / Size | PDF / 2.6 Mb |
ISM330DHCX Embedded low-power features 2 Embedded low-power features
The ISM330DHCX features the following on-chip functions: • 9 kbytes data buffering, data can be compressed two or three times – 100% efficiency with flexible configurations and partitioning – Possibility to store timestamp • Event-detection interrupts (fully configurable): – Free-fall – Wakeup – 6D orientation – Click and double-click sensing – Activity/inactivity recognition – Stationary/Motion detection • Specific IP blocks with negligible power consumption and high-performance: – Finite State Machine (FSM) for accelerometer, gyroscope, and external sensors – Machine Learning Core (MLC) – Significant Motion Detection, tilt, pedometer, step detector and step counters • Sensor hub – Up to 6 total sensors: 2 internal (accelerometer and gyroscope) and 4 external sensors
DS13012
Rev 5 page 4/167
Document Outline Features Applications Description 1 Overview 2 Embedded low-power features 2.1 Finite State Machine 2.2 Machine Learning Core 3 Pin description 3.1 Pin connections 4 Module specifications 4.1 Mechanical characteristics 4.2 Electrical characteristics 4.3 Temperature sensor characteristics 4.4 Communication interface characteristics 4.4.1 SPI - serial peripheral interface 4.4.2 I²C - inter-IC control interface 4.5 Absolute maximum ratings 4.6 Terminology 4.6.1 Sensitivity 4.6.2 Zero-g and zero-rate level 5 Digital interfaces 5.1 I²C/SPI interface 5.1.1 I²C serial interface 5.1.1.1 I²C operation 5.1.2 SPI bus interface 5.1.2.1 SPI read 5.1.2.2 SPI write 5.1.2.3 SPI read in 3-wire mode 5.2 Master I²C interface 5.3 Auxiliary SPI interface 6 Functionality 6.1 Operating modes 6.2 Gyroscope power modes 6.3 Accelerometer power modes 6.4 Block diagram of filters 6.4.1 Block diagrams of the accelerometer filters 6.4.2 Block diagrams of the gyroscope filters 6.5 FIFO 6.5.1 Bypass mode 6.5.2 FIFO mode 6.5.3 Continuous mode 6.5.4 Continuous-to-FIFO mode 6.5.5 Bypass-to-Continuous mode 6.5.6 Bypass-to-FIFO mode 6.5.7 FIFO reading procedure 7 Application hints 7.1 ISM330DHCX electrical connections in Mode 1 7.2 ISM330DHCX electrical connections in Mode 2 7.3 ISM330DHCX electrical connections in Mode 3 and Mode 4 8 Register mapping 9 Register description 9.1 FUNC_CFG_ACCESS (01h) 9.2 PIN_CTRL (02h) 9.3 FIFO_CTRL1 (07h) 9.4 FIFO_CTRL2 (08h) 9.5 FIFO_CTRL3 (09h) 9.6 FIFO_CTRL4 (0Ah) 9.7 COUNTER_BDR_REG1 (0Bh) 9.8 COUNTER_BDR_REG2 (0Ch) 9.9 INT1_CTRL (0Dh) 9.10 INT2_CTRL (0Eh) 9.11 WHO_AM_I (0Fh) 9.12 CTRL1_XL (10h) 9.13 CTRL2_G (11h) 9.14 CTRL3_C (12h) 9.15 CTRL4_C (13h) 9.16 CTRL5_C (14h) 9.17 CTRL6_C (15h) 9.18 CTRL7_G (16h) 9.19 CTRL8_XL (17h) 9.20 CTRL9_XL (18h) 9.21 CTRL10_C (19h) 9.22 ALL_INT_SRC (1A) 9.23 WAKE_UP_SRC (1Bh) 9.24 TAP_SRC (1Ch) 9.25 DRD_SRC (1Dh) 9.26 STATUS_REG (1Eh) / STATUS_SPIAux (1Eh) 9.27 OUT_TEMP_L (20h), OUT_TEMP_H (21h) 9.28 OUTX_L_G (22h) and OUTX_H_G (23h) 9.29 OUTY_L_G (24h) and OUTY_H_G (25h) 9.30 OUTZ_L_G (26h) and OUTZ_H_G (27h) 9.31 OUTX_L_A (28h) and OUTX_H_A (29h) 9.32 OUTY_L_A (2Ah) and OUTY_H_A (2Bh) 9.33 OUTZ_L_A (2Ch) and OUTZ_H_A (2Dh) 9.34 EMB_FUNC_STATUS_MAINPAGE (35h) 9.35 FSM_STATUS_A_MAINPAGE (36h) 9.36 FSM_STATUS_B_MAINPAGE (37h) 9.37 MLC_STATUS_MAINPAGE (38h) 9.38 STATUS_MASTER_MAINPAGE (39h) 9.39 FIFO_STATUS1 (3Ah) 9.40 FIFO_STATUS2 (3Bh) 9.41 TIMESTAMP0 (40h), TIMESTAMP1 (41h), TIMESTAMP2 (42h), and TIMESTAMP3 (43h) 9.42 TAP_CFG0 (56h) 9.43 TAP_CFG1 (57h) 9.44 TAP_CFG2 (58h) 9.45 TAP_THS_6D (59h) 9.46 INT_DUR2 (5Ah) 9.47 WAKE_UP_THS (5Bh) 9.48 WAKE_UP_DUR (5Ch) 9.49 FREE_FALL (5Dh) 9.50 MD1_CFG (5Eh) 9.51 MD2_CFG (5Fh) 9.52 INTERNAL_FREQ_FINE (63h) 9.53 INT_OIS (6Fh) 9.54 CTRL1_OIS (70h) 9.55 CTRL2_OIS (71h) 9.56 CTRL3_OIS (72h) 9.57 X_OFS_USR (73h) 9.58 Y_OFS_USR (74h) 9.59 Z_OFS_USR (75h) 9.60 FIFO_DATA_OUT_TAG (78h) 9.61 FIFO_DATA_OUT_X_L (79h) and FIFO_DATA_OUT_X_H (7Ah) 9.62 FIFO_DATA_OUT_Y_L (7Bh) and FIFO_DATA_OUT_Y_H (7Ch) 9.63 FIFO_DATA_OUT_Z_L (7Dh) and FIFO_DATA_OUT_Z_H (7Eh) 10 Embedded functions register mapping 11 Embedded functions register description 11.1 PAGE_SEL (02h) 11.2 EMB_FUNC_EN_A (04h) 11.3 EMB_FUNC_EN_B (05h) 11.4 PAGE_ADDRESS (08h) 11.5 PAGE_VALUE (09h) 11.6 EMB_FUNC_INT1 (0Ah) 11.7 FSM_INT1_A (0Bh) 11.8 FSM_INT1_B (0Ch) 11.9 MLC_INT1 (0Dh) 11.10 EMB_FUNC_INT2 (0Eh) 11.11 FSM_INT2_A (0Fh) 11.12 FSM_INT2_B (10h) 11.13 MLC_INT2 (11h) 11.14 EMB_FUNC_STATUS (12h) 11.15 FSM_STATUS_A (13h) 11.16 FSM_STATUS_B (14h) 11.17 MLC_STATUS (15h) 11.18 PAGE_RW (17h) 11.19 EMB_FUNC_FIFO_CFG (44h) 11.20 FSM_ENABLE_A (46h) 11.21 FSM_ENABLE_B (47h) 11.22 FSM_LONG_COUNTER_L (48h) and FSM_LONG_COUNTER_H (49h) 11.23 FSM_LONG_COUNTER_CLEAR (4Ah) 11.24 FSM_OUTS1 (4Ch) 11.25 FSM_OUTS2 (4Dh) 11.26 FSM_OUTS3 (4Eh) 11.27 FSM_OUTS4 (4Fh) 11.28 FSM_OUTS5 (50h) 11.29 FSM_OUTS6 (51h) 11.30 FSM_OUTS7 (52h) 11.31 FSM_OUTS8 (53h) 11.32 FSM_OUTS9 (54h) 11.33 FSM_OUTS10 (55h) 11.34 FSM_OUTS11 (56h) 11.35 FSM_OUTS12 (57h) 11.36 FSM_OUTS13 (58h) 11.37 FSM_OUTS14 (59h) 11.38 FSM_OUTS15 (5Ah) 11.39 FSM_OUTS16 (5Bh) 11.40 EMB_FUNC_ODR_CFG_B (5Fh) 11.41 EMB_FUNC_ODR_CFG_C (60h) 11.42 STEP_COUNTER_L (62h) and STEP_COUNTER_H (63h) 11.43 EMB_FUNC_SRC (64h) 11.44 EMB_FUNC_INIT_A (66h) 11.45 EMB_FUNC_INIT_B (67h) 11.46 MLC0_SRC (70h) 11.47 MLC1_SRC (71h) 11.48 MLC2_SRC (72h) 11.49 MLC3_SRC (73h) 11.50 MLC4_SRC (74h) 11.51 MLC5_SRC (75h) 11.52 MLC6_SRC (76h) 11.53 MLC7_SRC (77h) 12 Embedded advanced features pages 13 Embedded advanced features register description 13.1 Page 0 - Embedded advanced features registers 13.1.1 MAG_SENSITIVITY_L (BAh) and MAG_SENSITIVITY_H (BBh) 13.1.2 MAG_OFFX_L (C0h) and MAG_OFFX_H (C1h) 13.1.3 MAG_OFFY_L (C2h) and MAG_OFFY_H (C3h) 13.1.4 MAG_OFFZ_L (C4h) and MAG_OFFZ_H (C5h) 13.1.5 MAG_SI_XX_L (C6h) and MAG_SI_XX_H (C7h) 13.1.6 MAG_SI_XY_L (C8h) and MAG_SI_XY_H (C9h) 13.1.7 MAG_SI_XZ_L (CAh) and MAG_SI_XZ_H (CBh) 13.1.8 MAG_SI_YY_L (CCh) and MAG_SI_YY_H (CDh) 13.1.9 MAG_SI_YZ_L (CEh) and MAG_SI_YZ_H (CFh) 13.1.10 MAG_SI_ZZ_L (D0h) and MAG_SI_ZZ_H (D1h) 13.1.11 MAG_CFG_A (D4h) 13.1.12 MAG_CFG_B (D5h) 13.2 Page 1 - Embedded advanced features registers 13.2.1 FSM_LC_TIMEOUT_L (7Ah) and FSM_LC_TIMEOUT_H (7Bh) 13.2.2 FSM_PROGRAMS (7Ch) 13.2.3 FSM_START_ADD_L (7Eh) and FSM_START_ADD_H (7Fh) 13.2.4 PEDO_CMD_REG (83h) 13.2.5 PEDO_DEB_CONF (84h) 13.2.6 PEDO_SC_DELTAT_L (D0h) and PEDO_SC_DELTAT_H (D1h) 13.2.7 MLC_MAG_SENSITIVITY_L (E8h) and MLC_MAG_SENSITIVITY_H (E9h) 14 Sensor hub register mapping 15 Sensor hub register description 15.1 SENSOR_HUB_1 (02h) 15.2 SENSOR_HUB_2 (03h) 15.3 SENSOR_HUB_3 (04h) 15.4 SENSOR_HUB_4 (05h) 15.5 SENSOR_HUB_5 (06h) 15.6 SENSOR_HUB_6 (07h) 15.7 SENSOR_HUB_7 (08h) 15.8 SENSOR_HUB_8 (09h) 15.9 SENSOR_HUB_9 (0Ah) 15.10 SENSOR_HUB_10 (0Bh) 15.11 SENSOR_HUB_11 (0Ch) 15.12 SENSOR_HUB_12 (0Dh) 15.13 SENSOR_HUB_13 (0Eh) 15.14 SENSOR_HUB_14 (0Fh) 15.15 SENSOR_HUB_15 (10h) 15.16 SENSOR_HUB_16 (11h) 15.17 SENSOR_HUB_17 (12h) 15.18 SENSOR_HUB_18 (13h) 15.19 MASTER_CONFIG (14h) 15.20 SLV0_ADD (15h) 15.21 SLV0_SUBADD (16h) 15.22 SLAVE0_CONFIG (17h) 15.23 SLV1_ADD (18h) 15.24 SLV1_SUBADD (19h) 15.25 SLAVE1_CONFIG (1Ah) 15.26 SLV2_ADD (1Bh) 15.27 SLV2_SUBADD (1Ch) 15.28 SLAVE2_CONFIG (1Dh) 15.29 SLV3_ADD (1Eh) 15.30 SLV3_SUBADD (1Fh) 15.31 SLAVE3_CONFIG (20h) 15.32 DATAWRITE_SLV0 (21h) 15.33 STATUS_MASTER (22h) 16 Soldering information 17 Package information 17.1 LGA-14L package information 17.2 LGA-14 packing information Revision history Contents List of tables List of figures
