Datasheet LUXEON IR Domed (Lumileds)
Manufacturer | Lumileds |
Description | High power infrared emitters with engineered primary optics for high efficiency and beam control |
Pages / Page | 20 / 1 — Infrared. LUXeOn Ir domed Line. featUres and BenefIts. PrImary … |
File Format / Size | PDF / 2.4 Mb |
Infrared. LUXeOn Ir domed Line. featUres and BenefIts. PrImary aPPLIcatIOns
Infrared LUXeOn Ir domed Line
High power infrared emitters with engineered primary optics for high efficiency and beam control The LUXEON IR Domed Line high power infrared emitters are tailored to application needs by offering a variety of products at multiple infrared wavelengths and optical radiation patterns. LUXEON IR Domed Line is designed with innovative LUXEON technology to provide industry-leading performance. Through best-in-class thermal conductivity, LUXEON IR Domed Line has excellent performance at actual operating conditions. The LUXEON IR Domed Line uses an industry standard footprint for ease of integration and upgrading existing system designs.
featUres and BenefIts PrImary aPPLIcatIOns
Available in 850nm and 940nm wavelengths to provide optimized performance for each type of application Surveillance / CCTV Radiant Power of 1350mW (850nm) and 1450mW (940nm) for a greater system performance Machine Vision Option for higher drive current (up to 1.5A DC and 5A pulsed) available for applications requiring more performance 3D Scanning / Time of Flight Five emission patterns: 50°, 60°, 90°, 150° and an asymmetric radiation pattern of 95 x 58° Biometric Identification The five emission patterns address diverse application needs, high punch, long range and high uniformity User Interface Control 3.7mm x 3.7mm package with 3 pad configuration compatible with the industry standard footprint, enabling a direct upgrade in existing designs Augmented / Virtual Reality Ultra-low R of 2.5°C/W typ, the industry’s best thermal conductivity, solves th thermal challenges and supports space saving designs DS191 LUXEON IR Domed Line Product Datasheet ©2020 Lumileds Holding B.V. All rights reserved. Document Outline General Product Information Product Test Conditions Part Number Nomenclature Radiometric Power Maintenance Environmental Compliance Performance Characteristics Product Selection Guide Optical Characteristics Electrical and Thermal Characteristics Absolute Maximum Ratings Characteristic Curves Spectral Power Distribution Characteristics Light Output Characteristics Forward Current Characteristics Wavelength Shift Characteristics Radiation Pattern Characteristics Permissible Pulse Handling Characteristics Product Bin and Labeling Definitions Decoding Product Bin Labeling Radiometric Power Bins Peak Wavelength Bins Forward Voltage Bins Mechanical Dimensions Reflow Soldering Guidelines JEDEC Moisture Sensitivity Solder Pad Design Packaging Information Pocket Tape Dimensions Reel Dimensions
