Datasheet LUXEON IR Domed (Lumileds) - 3
Manufacturer | Lumileds |
Description | High power infrared emitters with engineered primary optics for high efficiency and beam control |
Pages / Page | 20 / 3 — General Product Information. A A A B B B B. A A A. B B B B. 8 5 0 0 6 0 … |
File Format / Size | PDF / 2.4 Mb |
General Product Information. A A A B B B B. A A A. B B B B. 8 5 0 0 6 0 0. A A A B B B C. B B B. 8 5 0 0 6 0 2
Product Test Conditions LUXEON IR Domed Line emitters are tested and binned with a 20ms monopulse of 1000mA at a junction temperature, T, of 25°C. j Part Number Nomenclature Part numbers for LUXEON IR Domed Line (max drive current (DC) of 1A) follow the convention below: L 1 I 0 – 0
A A A B B B B
0 0 0 0 0 Where:
A A A
– designates nominal peak wavelength
B B B B
– designates full width half maximum (FWHM) of the emitter’s radiation pattern (60°=0600, 90°=0900, 150°=1500, 95 x 58°=9558) 0 0 0 0 0 – reserved for further customization Therefore, the following part number is used for a LUXEON IR Domed emitter with a peak wavelength of 850nm and a FWHM beam angle of 60°: L 1 I 0 – 0
8 5 0 0 6 0 0
0 0 0 0 0 Part numbers for LUXEON IR Domed Line (max drive current (DC) of 1.5A) follow the convention below: L 1 I 0 – 0
A A A B B B C
0 0 0 0 0 Where:
A A A
B B B
– designates full width half maximum (FWHM) of the emitter’s radiation pattern (50°=050, 60°=060, 90°=090, 150°=150)
C
– designates max drive current capability (2=1.5A) 0 0 0 0 0 – reserved for further customization Therefore, the following part number is used for a LUXEON IR Domed emitter with a peak wavelength of 850nm, a FWHM beam angle of 60° and a max driving current of 1.5A: L 1 I 0 – 0
8 5 0 0 6 0 2
0 0 0 0 0 Radiometric Power Maintenance Please contact your local Sales Representative or Lumileds Technical Solutions Manager for more information about the long- term performance of this product. DS191 LUXEON IR Domed Line Product Datasheet 20200403 ©2020 Lumileds Holding B.V. All rights reserved. 2 Document Outline General Product Information Product Test Conditions Part Number Nomenclature Radiometric Power Maintenance Environmental Compliance Performance Characteristics Product Selection Guide Optical Characteristics Electrical and Thermal Characteristics Absolute Maximum Ratings Characteristic Curves Spectral Power Distribution Characteristics Light Output Characteristics Forward Current Characteristics Wavelength Shift Characteristics Radiation Pattern Characteristics Permissible Pulse Handling Characteristics Product Bin and Labeling Definitions Decoding Product Bin Labeling Radiometric Power Bins Peak Wavelength Bins Forward Voltage Bins Mechanical Dimensions Reflow Soldering Guidelines JEDEC Moisture Sensitivity Solder Pad Design Packaging Information Pocket Tape Dimensions Reel Dimensions
