Datasheet AD8565, AD8566, AD8567 (Analog Devices)
Description | 16 V Rail-to-Rail Operational Amplifiers |
Pages / Page | 13 / 1 — 16 V Rail-to-Rail. Operational Amplifiers. Data Sheet. AD8565/. AD8566/. … |
Revision | H |
File Format / Size | PDF / 335 Kb |
16 V Rail-to-Rail. Operational Amplifiers. Data Sheet. AD8565/. AD8566/. AD8567. FEATURES. PIN CONFIGURATIONS
16 V Rail-to-Rail Operational Amplifiers Data Sheet AD8565/ AD8566/ AD8567 FEATURES PIN CONFIGURATIONS Single-supply operation: 4.5 V to 16 V AD8565 Input capability beyond the rails OUT 1 5 V– Rail-to-rail output swing V+ 2 Continuous output current: 35 mA +IN 3 4 –IN
01 0
Peak output current: 250 mA TOP VIEW (Not to Scale) Offset voltage: 10 mV
01909- Figure 1. 5-Lead SC70 Pin Configuration
Slew rate: 6 V/μs Unity gain stable with large capacitive loads OUT A 1 AD8566 8 V+ Supply current: 700 μA per amplifier Qualified for automotive applications –IN A 2 7 OUT B APPLICATIONS +IN A 3 6 –IN B LCD reference drivers V– 4 5 +IN B
2
TOP VIEW
00
Portable electronics (Not to Scale)
9- 90 01
Communications equipment
Figure 2. 8-Lead MSOP Pin Configuration
Automotive infotainment systems GENERAL DESCRIPTION OUT A 1 14 OUT D
The AD8565/AD8566/AD8567 are low cost, single-supply, rail-
–IN A 2 3 1 –IN D
to-rail input and output operational amplifiers optimized for LCD monitor applications. They are built on an advanced high
+IN A 3 12 +IN D
voltage CBCMOS process. The AD8565 contains a single
AD8567 TOP VIEW
amplifier, the AD8566 has two amplifiers, and the AD8567 has
V+ 4 11 V– (Not to Scale)
four amplifiers.
+IN B 5 10 +IN C
These LCD op amps have high slew rates, 35 mA continuous output drive, 250 mA peak output drive, and a high capacitive
–IN B 6 9 –IN C
load drive capability. They have a wide supply range and offset 03
OUT B 7 8 OUT C
-0 voltages below 10 mV. The AD8565/AD8566/AD8567 are ideal 909 01 for LCD grayscale reference buffer and VCOM applications. Figure 3. 14-Lead TSSOP Pin Configuration The AD8565/AD8566/AD8567 are specified over the −40°C to
A D T T
+85°C temperature range. The AD8565 single is available in a
NC OU OU NC
5-lead SC70 package. The AD8566 dual is available in an 8-lead
61 5 3 1 41 1
MSOP package. The AD8567 quad is available in a 14-lead TSSOP package and a 16-lead LFCSP package.
–IN A 1 12 –IN D +IN A 2 11 +IN D AD8567
The AD8566WARMZ is the automotive grade version.
V+ 3 TOP VIEW 10 V– (Not to Scale) +IN B 4 9 +IN C 5 6 7 8 B B C C N T T N –I OU OU –I NOTES 1. THE EXPOSED PAD MUST BE
4
CONNECTED TO PIN 3, THAT IS, V+.
-00 09
2. NC = NO CONNECT.
019 Figure 4. 16-Lead LFCSP Pin Configuration
Rev. H Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2001–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL POWER DISSIPATION THERMAL PAD—AD8567 TOTAL HARMONIC DISTORTION + NOISE (THD + N) SHORT-CIRCUIT OUTPUT CONDITIONS LCD PANEL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
