HMC983LP5E v02.0112 DC - 7 GHz FRACTIONAL-N DIVIDERAND FREQUENCY SWEEPERTypical ApplicationsFeatures (Continued) the Dc - 7 GHz FrActionAL-n DiviDer is suitable integrated Frequency sweeper t for: - Linear, coherent sweeps M • test equipment - 2-Way, 1-Way, & user Defined sweep Modes s - Automatic or triggered • Portable instruments - Programmable seed • High Performance Fractional-n Frequency synthe- -sPi & external triggering s - sizers with ultra Low spurious 5-GPio’s, can be used for external DsM r • stand-Alone Divider and/or Delta-sigma Modulator cycle slip Prevention support with PFD chip o Features (HMc984LP4e) t Wideband: Dc - 7 GHz input Differential vco input & Divider output c -20-bit Frequency Divider e Programmable output current control: t Low noise: -160 dBc/Hz -5 mA to 17.5 mA open col ector output Driver e Low spurious: Largest spurious - 95 dBc 32 pin, 5 x 5 mm, LP5 Package 48-bit 100 MHz Delta-sigma Modulator (DsM) - configurable DsM size - Programmable seed s & D - Phase step r General Description e Functional Diagram Dc - 7 GHz FrActionAL-n DiviDer is a fractional iD frequency divider targeted for fractional-n frequency synthesis, and stand-alone low noise frequency iv divider applications that require exceptional spurious performance. y D Although the Dc - 7 GHz FrActionAL-n DiviDer c can work with any vco and/or compatible Phase n Detector, best performance and features will be achieved when paired with the companion part, the e HMc984LP4e. u Fabricated in siGe BicMos process, the q Dc - 7 GHz FrActionAL-n DiviDer features a e 48-bit Delta sigma Fractional Modulator (DsM) with r programmable phase accumulator size, enabling F precise control of frequency step size and resolution. integrated DsM can generate frequencies with nearly 0 Hz frequency error. the DsM also includes a built-in programmable frequency sweep capability, with various automatic and user defined sweep modes and triggering options, including hardware trigger pin, or sPi trigger with optional delayed trigger. Dc - 7 GHz FrActionAL-n DiviDer is a versatile part capable of various configurations. it has 5 general purpose i/os (GPios). DsM outputs are made available from the GPio port, enabling the Dc - 7 GHz FrActionAL-n DiviDer to import and/ or export DsM sequences for various configuration options. Dc - 7 GHz FrActionAL-n DiviDer divider outputs are differential, open col ector with programmable Product covered by US and Foreign Patents including US Pat. No. 8,531,217. current to accommodate different off-chip loads. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m 1 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
