Datasheet HMC434 (Analog Devices) - 3
Description0.2 GHz to 8 GHz, GaAs, HBT MMIC, Divide by 8 Prescaler
Pages / Page9 / 3 — Data Sheet. HMC434. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. …
RevisionG
File Format / SizePDF / 348 Kb
Data Sheet. HMC434. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit. Test Conditions / Comments
Data Sheet HMC434 SPECIFICATIONS Table 1 Parameter Min Typ Max Unit Test Conditions / Comments
VCC = 3 V, TA = 25°C, 50 Ω system, unless otherwise noted. PIN is input power.
Table 1. Parameter Min Typ Max Unit Test Conditions / Comments
RADIO FREQUENCY (RF) INPUT Frequency 1, 2 0.2 8 GHz Sine wave input Power –10 0 +10 dBm fIN = 1.0 GHz to 3.0 GHz 0 0 10 dBm fIN = 3.0 GHz to 8.0 GHz RF OUTPUT SSB Phase Noise −150 dBc/Hz 100 kHz offset, PIN = 0 dBm, fIN = 4.0 GHz Power –5 –2 dBm fIN = 1.0 GHz to 8.0 GHz REVERSE LEAKAGE −25 dBm PIN = 0 dBm, fIN = 4.0 GHz, output terminated SUPPLY Voltage (VCC) 2.85 3 3.15 V Current (ICC) 62 83 mA 1 Below 200 MHz, a square wave input is required. 2 For stable operation without an input signal, refer to AN-1463. Rev. G | Page 3 of 9 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Applications Information Evaluation Board PCB PCB Material Stackup Outline Dimensions Ordering Guide
