Datasheet HMC434 (Analog Devices) - 6
Description0.2 GHz to 8 GHz, GaAs, HBT MMIC, Divide by 8 Prescaler
Pages / Page9 / 6 — HMC434. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. MAX PIN, TA = …
RevisionG
File Format / SizePDF / 348 Kb
HMC434. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. MAX PIN, TA = +85°C. MIN P. IN, TA = +85°C. RECOMMENDED. MAX PIN, TA = +25°C
HMC434 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS MAX PIN, TA = +85°C MIN P IN, TA = +85°C RECOMMENDED MAX PIN, TA = +25°C
link to page 6
In Figure 9, PFEEDTHROUGH is the power of the output spectrum at the input frequency.
20 20 15 15 10 10 ) ) m m MAX PIN, TA = +85°C B B MIN P 5 5 IN, TA = +85°C (d RECOMMENDED (d MAX PIN, TA = +25°C OPERATING WINDOW MIN PIN, TA = +25°C WER 0 WER 0 MAX P O O IN, TA = –40°C P P MIN PIN, TA = –40°C T T U –5 U –5 P P IN IN –10 –10 –15 –15 MAX PIN MIN P –20 IN –20 0 1 2 3 4 5 6 7 8 9 10
007
010 84- 84-
INPUT FREQUENCY (GHz)
156
156 Figure 7. Input Sensitivity Window Figure 10. Input Sensitivity Window at Various Temperatures
5 0 TA = +85°C –10 4 TA = +25°C T –20 A = –40°C –30 3 z) –40 ) H m 2 –50 Bc/ dB –60 ( (d R 1 E –70 IS –80 0 OWE NO –90 P T –100 U –1 TP –110 PHASE –2 B –120 OU S S –130 –3 –140 –150 –4 –160 –5 –170 0 1 2 3 4 5 6 7 8 9 10
008
100 1k 10k 100k 1M 10M
-011 84- 684
INPUT FREQUENCY (GHz) OFFSET FREQUENCY (Hz)
156 15 Figure 8. Output Power vs. Frequency at Various Temperatures Figure 11. Residual SSB Phase Noise (Carrier Frequency = 320 MHz, PIN = 0 dBm)
0 0 –5 –5 –10 –10 –15 c) B –15 –20 m) d B ( R –25 (d –20 VEL OWE –30 E –25 P L T –35 R U E –30 P T W –40 U O PO –35 –45 –30 –50 PFEEDTHROUGH –55 SECOND HARMONIC –45 THIRD HARMONIC –60 –50 0 1 2 3 4 5 6 7 8 9 10
009
012 84- 84-
INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz)
156 156 Figure 9. Output Harmonic Content (PIN = 0 dBm) Figure 12. Reverse Leakage (PIN = 0 dBm) Rev. G | Page 6 of 9 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Applications Information Evaluation Board PCB PCB Material Stackup Outline Dimensions Ordering Guide
