Datasheet LTM8025 (Analog Devices) - 6
Description36V, 3A Step-Down µModule Regulator
Pages / Page22 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. …
RevisionD
File Format / SizePDF / 974 Kb
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Input Current vs Input Voltage
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Input Current vs Input Voltage
LTM8025
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Input Current vs Input Voltage Minimum Input Running Voltage Minimum Input Voltage vs Load Output Shorted vs VOUT, IOUT = 3A Current, 3.3VOUT
600 40 6.0 TO RUN 35 TO START 500 5.5 RUN/SS CONTROLLED 30 400 5.0 25 TAGE (V) TAGE (V) 300 20 4.5 15 200 4.0 INPUT CURRENT (mA) INPUT VOL INPUT VOL 10 100 3.5 5 0 0 3.0 0 10 20 30 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 0 1000 2000 3000 INPUT VOLTAGE (V) OUTPUT VOLTAGE (V) LOAD CURRENT (mA) 8025 G19 8025 G20 8025 G21
Minimum Input Voltage vs Load Minimum Input Voltage vs Load Minimum Input Voltage vs Load Current, 5VOUT Current, 8VOUT Current, 12VOUT
7.5 11.0 22 TO RUN TO RUN TO RUN TO START TO START 21 TO START 7.0 RUN/SS CONTROLLED 10.5 RUN/SS CONTROLLED RUN/SS CONTROLLED 20 6.5 19 10.0 6.0 18 TAGE (V) TAGE (V) TAGE (V) 9.5 17 5.5 16 INPUT VOL 9.0 5.0 INPUT VOL INPUT VOL 15 14 4.5 8.5 13 4.0 8.0 12 0 1000 2000 3000 0 1000 2000 3000 0 1000 2000 3000 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 8025 G22 8025 G23 8025 G24
Minimum Input Voltage vs Load Minimum Input Voltage vs Load Minimum Input Voltage vs Load Current, 18VOUT Current, –3.3VOUT Current, –5VOUT
10 14 TO RUN TO RUN 9 TO START TO START 32 RUN/SS CONTROLLED 12 RUN/SS CONTROLLED 8 7 10 27 6 TAGE (V) TAGE (V) 8 TAGE (V) 5 22 4 6 INPUT VOL INPUT VOL 3 INPUT VOL 4 17 TO RUN 2 TO START 2 1 RUN/SS CONTROLLED 12 0 0 0 1000 2000 3000 0 1000 2000 3000 0 1000 2000 3000 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 8025 G25 8025 G26 8025 G27 Rev. D 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Package Photography Typical Application Related Parts
