Datasheet LTM8025 (Analog Devices) - 7
Description | 36V, 3A Step-Down µModule Regulator |
Pages / Page | 22 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. … |
Revision | D |
File Format / Size | PDF / 974 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Minimum Input Voltage vs Load
LTM8025
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Minimum Input Voltage vs Load Minimum Input Voltage vs Load Minimum Input Voltage vs Current, –8VOUT Current, –12VOUT Negative VOUT
20 30 25 TO RUN TO RUN 1A TO START TO START 2A RUN/SS CONTROLLED 25 RUN/SS CONTROLLED 3A 20 15 20 15 TAGE (V) TAGE (V) TAGE (V) 10 15 10 INPUT VOL 10 INPUT VOL INPUT VOL 5 5 5 0 0 0 0 1000 2000 3000 0 1000 2000 3000 0 –5 –10 –15 LOAD CURRENT (mA) LOAD CURRENT (mA) OUTPUT VOLTAGE (V) 8025 G28 8025 G29 8025 G13
Junction Temperature Rise vs Junction Temperature Rise vs Junction Temperature Rise vs Load Current, 2.5VOUT Load Current, 3.3VOUT Load Current, 5VOUT
45 60 50 5VIN 5VIN 12VIN 40 12VIN 12VIN 45 24VIN 24VIN 50 24VIN 32VIN 35 32V 40 IN 32VIN 35 30 40 30 25 30 25 TURE RISE (°C) 20 TURE RISE (°C) TURE RISE (°C) 20 15 20 15 TEMPERA 10 TEMPERA TEMPERA 10 10 5 5 0 0 0 0 500 1000 1500 2000 2500 3000 3500 0 500 1000 1500 2000 2500 3000 3500 0 500 1000 1500 2000 2500 3000 3500 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 8025 G31 8025 G32 8025 G33
Junction Temperature Rise vs Junction Temperature Rise vs Junction Temperature Rise vs Load Current, 8VOUT Load Current, 12VOUT Load Current, 18VOUT
80 120 100 12VIN 16VIN 24VIN 70 24VIN 24VIN 32VIN 32VIN 100 32VIN 80 60 80 50 60 40 60 TURE RISE (°C) TURE RISE (°C) TURE RISE (°C) 30 40 40 TEMPERA 20 TEMPERA TEMPERA 20 20 10 0 0 0 0 500 1000 1500 2000 2500 3000 3500 0 500 1000 1500 2000 2500 3000 0 500 1000 1500 2000 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 8025 G34 8025 G35 8025 G36 Rev. D For more information www.analog.com 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Package Photography Typical Application Related Parts
