Datasheet T3902 (TDK) - 5
ManufacturerTDK
DescriptionBottom Port PDM Low‐Power Multi‐Mode Microphone With High AOP Mode
Pages / Page22 / 5 —  T3902. TABLE 3. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – STANDARD MODE . …
File Format / SizePDF / 446 Kb
 T3902. TABLE 3. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – STANDARD MODE . PARAMETER   . CONDITIONS . MIN . TYP . MAX . UNITS . NOTES
 T3902 TABLE 3. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – STANDARD MODE  PARAMETER    CONDITIONS  MIN  TYP  MAX  UNITS  NOTES
   T3902
TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 2.4 MHz, 50× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not  guaranteed.
Sensitivity  1 kHz, 94 dB SPL  −27  −26  −25  dB FS  1, 2  Signal‐to‐Noise Ratio (SNR)  20 kHz bandwidth, A‐weighted    64.5    dBA    Equivalent Input Noise (EIN)  20 kHz bandwidth, A‐weighted    29.5    dBA SPL    Dynamic Range  Derived from EIN and AOP    90.5    dB    Low frequency −3 dB point      36    Hz  3  Total Harmonic Distortion (THD)  105 dB SPL     0.2  1  %    Power Supply Rejection (PSR)  217 Hz, 100 mV p‐p square wave  superimposed on VDD = 1.8 V, A‐   −97    dB FS    weighted  Power Supply Rejection—Swept  1 kHz sine wave  −104  dB FS        Sine  Acoustic Overload Point  10% THD    120    dB SPL    Full‐Scale Acoustic Level  0 dB FS output    120    dB SPL    Supply Current (IS)  VDD = 1.8 V, no load    430  500  µA
Note 1:
  Sensitivity is relative to the RMS level of a sine wave with positive amplitude equal to 100% 1s density and negative amplitude equal to 0% 1s density.
Note 2:
The sensitivity shall not deviate more than 1.0 dB from its initial value after reliability tests.
  Note 3:
  See See Figure 4.
TABLE 4. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – LOW‐POWER MODE
TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 768 kHz, 50× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not  guaranteed.
Sensitivity  1 kHz, 94 dB SPL  −27  −26  −25  dB FS  1, 2  Signal‐to‐Noise Ratio (SNR)  8 kHz bandwidth, A‐weighted    63    dBA    Equivalent Input Noise (EIN)  8 kHz bandwidth, A‐weighted    31    dBA SPL    Dynamic Range  Derived from EIN and AOP    89    dB    Low frequency −3 dB point      36    Hz  3  Total Harmonic Distortion (THD)  105 dB SPL     0.2  1  %    Power Supply Rejection (PSR)  217 Hz, 100 mV p‐p square wave  superimposed on VDD = 1.8 V, A‐   −97    dB FS    weighted  Power Supply Rejection—Swept  1 kHz sine wave  −98  dB FS        Sine  Acoustic Overload Point  10% THD    120    dB SPL    Full‐Scale Acoustic Level  0 dB FS output    120    dB SPL    Supply Current (IS)  VDD = 1.8 V, no load    185  225  µA
Note 1:
Note 2:
  Note 3:
  See Figure 4.
Page 5 of 22  Document Number: DS‐000357  Revision: 1.0
