Datasheet T3902 (TDK) - 10
ManufacturerTDK
DescriptionBottom Port PDM Low‐Power Multi‐Mode Microphone With High AOP Mode
Pages / Page22 / 10 —  T3902. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS . GND. SELECT. CLK. …
File Format / SizePDF / 446 Kb
 T3902. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS . GND. SELECT. CLK. DATA. VDD
 T3902 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS  GND SELECT CLK DATA VDD
   T3902
3 GND SELECT 4 2 CLK DATA 5 1 VDD
Figure 3. Pin Configuration (Top View, Terminal Side Down)
TABLE 9. PIN FUNCTION DESCRIPTIONS  PIN  NAME  FUNCTION
1  DATA  Digital Output Signal (DATA1 or DATA2)  Left Channel or Right Channel Select:  DATA 1 (right): SELECT tied to GND  2  SELECT  DATA 2 (left):  SELECT tied to VDD. In this setting, SELECT should be tied to the same voltage  source as the VDD pin.   3  GND  Ground  4  CLK  Clock Input to Microphone  Power Supply. For best performance and to avoid potential parasitic artifacts, place a 0.1 µF  5  VDD  (100 nF) ceramic type X7R capacitor between Pin 5 (VDD) and ground. Place the capacitor as  close to Pin 5 as possible.   Page 10 of 22  Document Number: DS‐000357  Revision: 1.0
