Datasheet ACS37002 (Allegro) - 38
ManufacturerAllegro
Description400 kHz, High Accuracy Current Sensor with Pin-Selectable Gains and Adjustable Overcurrent Fast Fault in SOICW-16 Package
Pages / Page39 / 38 — 400 kHz, High Accuracy Current Sensor. ACS37002
400 kHz, High Accuracy Current Sensor ACS37002
link to page 3
400 kHz, High Accuracy Current Sensor ACS37002 with Pin-Selectable Gains and Adjustable Overcurrent Fast Fault in SOICW-16 Package
10.30 ±0.20 8° 0° 16 D D2 0.33 D1 0.20 7.50 ±0.10 10.30 ±0.33 2.466 1.513 A D D 1.40 REF 1 2 1.27 0.40 Branded Face 0.25 BSC SEATING PLANE 16× C SEATING GAUGE PLANE SEATING 0.10 C PLANE 1.27 BSC 2.65 MAX 0.51 0.31 0.30 ACS37002 (5 V) ACS37002 (3.3 V) 0.10 ACS37002 ACS37002 For Reference Only; not for tooling use (reference MS-013AA) Lot Number Lot Number Dimensions in millimeters Dimensions exclusive of mold flash, gate burrs, and dambar protrusions Exact case and lead configuration at supplier discretion within limits shown 1 1 A Terminal #1 mark area B Branding scale and appearance at supplier discretion B Standard Branding Reference View C Reference land pattern layout (reference IPC7351 Line 1: Part Number SOIC127P600X175-8M); all pads a minimum of 0.20 mm from all Line 2: First 9 characters of Assembly Lot Number adjacent pads; adjust as necessary to meet application process requirements and PCB layout tolerances D Hall elements (D1, D2); not to scale 1.27 1.27 16 0.65 16 0.65 2.25 1.65 9.50 9.75 1 2 1 2 C PCB Layout Reference View High-Isolation PCB Layout Reference View
Figure 27: Package LA, 16-PIN SOICW
38 Allegro MicroSystems 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com Document Outline Features and Benefits Description Packages Selection guide Absolute Maximum Ratings Isolation Characteristics MA Package Specific Performance LA Package Specific Performance Pinout Diagram and Terminal List Functional Block Diagram Common Electrical Characteristics Performance Characteristics Functional Description Power-On Reset Operation Power-On Power-Off Power-On Timing Power-On Reset (POR) Overvoltage and Undervoltage Detection Undervoltage Detection Voltage Thresholds (VUVD(H/L)) Overvoltage Detection Voltage Thresholds (VOVD(H/L)) Overvoltage/Undervoltage Detection Hysteresis (VOVDHys, VUVDHys) Overvoltage and Undervoltage Enable and Disable Time (tOVD(E/D), tUVD(E/D)) Supply Zener Clamp Voltages Absolute Maximum Ratings Forward and Reverse Supply Voltage Forward and Reverse Output Voltage Forward and Reverse Reference/Fault Voltage Output Source and Sink Current Definitions of Operating and PErformance Characteristics Zero Current Voltage Output (VIOUT(Q), QVO) QVO Temperature Drift (VQE) Reference Voltage (VREF) Reference Voltage Temperature Drift (VRE) Offset Voltage (VOE) Output Saturation Voltage (VSAT(HIGH/LOW)) Sensitivity (Sens) Sensitivity Error (Esens) Gain Selection Pins Full Scale (FS) Nonlinearity (ELIN) Total Output Error (ETOT) Power Supply Offset Error (VPS) Offset Power Supply Rejection Ratio (PSRRO) Power Supply Sensitivity Error (EPS) Sensitivity Power Supply Rejection Ratio (PSRRS) Fault Behavior Overcurrent Fault (OCF) Overcurrent Fault Operating Range/Point (IOCF-OR, IOCF-OP) Overcurrent Fault Hysteresis (IOCF-Hyst) Voltage Overcurrent Pin (VOC) OverCurrent Fault Error (EOCF) OverCurrent Fault Response Time (tOCF) OverCurrent Fault Reaction Time (tOCF-R) OverCurrent Fault Mask Time (tOCF-MASK) OverCurrent Fault Hold Time (tOCF-HOLD) OverCurrent Fault Persist OCF Disable Dynamic Response Parameters Propagation Time (tpd) Rise Time (tR) Response Time (tRESPONSE) Overshoot Settling Time Temperature Compensation Temperature Compensation Update Rate Application and Theory Application Circuits Theory and Functionality – VOC and OCF VOC Driven by Non-Inverting Buffered VREF Power Supply Decoupling Capacitor and Output Capacitive Loads Dynamically Change Gain in a System Thermal Performance Thermal Rise vs. Primary Current Evaluation Board Layout Package Outline Drawings MA Package LA Package
