Datasheet ADRV9026 (Analog Devices) - 10
DescriptionIntegrated, Quad RF Transceiver with Observation Path
Pages / Page118 / 10 — ADRV9026. Data Sheet. Parameter. Symbol. Min Typ. Max. Unit. Test …
ADRV9026. Data Sheet. Parameter. Symbol. Min Typ. Max. Unit. Test Conditions/Comments
ADRV9026 Data Sheet Parameter Symbol Min Typ Max Unit Test Conditions/Comments
4800 MHz −69.8 dBc 5700 MHz −66 dBc Fifth-Order Intermodulation IM5 Product Narrow Band IM5NB IM5 product < 130 MHz at baseband; test condition: two tones, each at PHIGH − 11 dB, 491.52 MSPS 800 MHz −83 dBc 1800 MHz −87 dBc 2600 MHz −84 dBc 3800 MHz −80 dBc 4800 MHz −78 dBc 5700 MHz −81 dBc Wide Band IM5WB IM5 product > 130 MHz at baseband; test condition:two tones, each at PHIGH − 11 dB, 491.52 MSPS 800 MHz −83 dBc 1800 MHz −96 dBc 2600 MHz −85 dBc 3800 MHz −80 dBc 4800 MHz −77 dBc 5700 MHz −85 dBc Seventh-Order Intermodulation IM7 Product Narrow Band IM7NB IM7 product < 130 MHz at baseband; test condition: two tones, each at PHIGH − 11 dB, 491.52 MSPS 800 MHz −74 dBc 1800 MHz −78 dBc 2600 MHz −75 dBc 3800 MHz −73 dBc 4800 MHz −78 dBc 5700 MHz −75 dBc Wide Band IM7WB IM7 product > 130 MHz at baseband; test condition: two tones, each at PHIGH − 11 dB, 491.52 MSPS 800 MHz −83 dBc 1800 MHz −82 dBc 2600 MHz −83 dBc 3800 MHz −83 dBc 4800 MHz −85 dBc 5700 MHz −81 dBc Spurious-Free Dynamic Range SFDR 64 dB Nonintermodulation related spurs; does not in- clude harmonic distortion; input set at PHIGH − 8 dB Second-Order Harmonic Distortion HD2 Input set at PHIGH − 8 dB In Band −80 dBc In-band harmonic distortion falls within ±100 MHz Out of Band −73 dBc Out of band harmonic distortion falls within ±225 MHz Third-Order Harmonic Distortion HD3 Input set at PHIGH − 8 dB In Band −70 dBc Harmonic distortion falls within ±100 MHz Out of Band −65 dBc Harmonic distortion falls within ±225 MHz Image Rejection 75 dB After online tone calibration, QEC active Tx to ORx Signal Isolation: Al Tx 75 dB Output Effects on al ORx Inputs Rev. A | Page 10 of 118 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Transmitters and Receivers Synthesizers, Auxiliary Converters, and Clock References Digital Specifications Power Supply Specifications Current Consumption TDD Operation—Four Receiver Channels Enabled TDD Operation—Four Transmitter and One Observation Receiver Channels Enabled FDD Operation—LO1 and LO2, Four Receiver, Four Transmitter, and One Observation Receiver Channels Enabled Digital Interface and Timing Specifications Absolute Maximum Ratings Junction Temperature Reflow Profile Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 800 MHz Band 1800 MHz Band 2600 MHz Band 3800 MHz Band 4800 MHz Band 5700 MHz Band Theory of Operation General Transmitter Receiver Observation Receiver Clock Input Synthesizers RF Synthesizers Auxiliary Synthesizer Clock Synthesizer SPI Interface GPIO_x Pins Auxiliary Converters GPIO_ANA_x/AUXDAC_x AUXADC_x JTAG Boundary Scan Applications Information Power Supply Sequence Data Interface Outline Dimensions Ordering Guide
