Datasheet RN41XV (Microchip) - 4
ManufacturerMicrochip
DescriptionEvaluation Board
Pages / Page6 / 4 — RN-XV-EK-DS. PHYSICAL DIMENSIONS. DESIGN CONCERNS. Powering the Module. …
File Format / SizePDF / 559 Kb
RN-XV-EK-DS. PHYSICAL DIMENSIONS. DESIGN CONCERNS. Powering the Module. GPIO9 Functions. NOTE:. Setting. AP Mode Default
RN-XV-EK-DS PHYSICAL DIMENSIONS DESIGN CONCERNS Powering the Module GPIO9 Functions NOTE: Setting AP Mode Default
Figure 2 shows the evaluation board’s physical dimensions.
DESIGN CONCERNS
The fol owing sections provide information on designing with the RN-XV-EK module.
Powering the Module
When plugged in, the module receives power from the PC via the USB cable.
GPIO9 Functions
The AP pushbutton is connected to GPIO9. Depending on the state of GPIO9, the module goes into three different modes: access point (AP) mode, factory reset, and WPS mode. To put the module into AP mode, GPIO9 must be high when the module powers up or wakes from a sleep state. Press the AP mode button to drive GPIO9 high, and then press the reset button to reset the module. The module is in default AP mode, which creates a default access point network with the default parameters shown in Table 1.
NOTE:
This default mode overwrites any software settings. ! " # $ % &
SSID WiFlyAP-XX, where XX is the last two bytes of the module’s MAC address Channel 1 DHCP server Enabled IP address 1.2.3.4 Netmask 255.255.255.0 www.rovingnetworks.com Version 0.01 9/25/2012 4
