Datasheet RN41XV (Microchip) - 5
ManufacturerMicrochip
DescriptionEvaluation Board
Pages / Page6 / 5 — RN-XV-EK-DS. set sys trigger 0x10. Reset. Drivers. RESOURCES & …
File Format / SizePDF / 559 Kb
RN-XV-EK-DS. set sys trigger 0x10. Reset. Drivers. RESOURCES & RELATED DOCUMENTS
RN-XV-EK-DS set sys trigger 0x10 Reset Drivers RESOURCES & RELATED DOCUMENTS
RN-XV-EK-DS
Gateway 1.2.3.4 When the module boots, other Wi-Fi-enabled devices (PC, iPhone, iPad, Android tablet, etc.) should be able to see the module when they scan for access points. In this mode, the module is restored to the factory defaults. To restore the defaults, perform he fol owing steps: 1. Put the module into default AP mode as described in “AP Mode”. 2. Press the AP Mode pushbutton 5 times (with 1 or more seconds between presses). The module is restored to the initial factory default configuration. This setting is useful for cases in which the module is misconfigured and is no longer responding. When the module is acting as a client (not in access point mode), you can invoke WPS functionality by pressing the AP pushbutton. Before you can invoke this mode, the WPS functionality must enabled in software using the command
Reset
The Reset pushbutton reboots the module. You can use the Reset and AP pushbuttons to toggle whether the module is in client or AP mode. If you press the P pushbutton before pressing Reset, the module goes into default AP mode. If you press the Reset button only, the module goes into client mode.
Drivers
RN-XV-EK board uses the FTDI chip set. When you connect the cable, the PC should instal the drivers automatical y. If not, you can download the drivers from the Support page on the Roving Networks website at http://www.rovingnetworks.com/support.php.
For more information, refer to the fol owing sources, which are available on the Support page on the Roving Networks website at http://www.rovingnetworks.com/support.php: • RN-XV Data Sheet • RN-171 Data Sheet • WiFly Advanced User Manual • WiFly Training Presentation • Drivers, tools, and utilities www.rovingnetworks.com Version 0.01 9/25/2012 5
