Datasheet ADCMP380 (Analog Devices) - 3
DescriptionUltralow Power Voltage Comparator with Reference
Pages / Page10 / 3 — Data Sheet. ADCMP380. SPECIFICATIONS. Table 2. Parameter. Symbol. Min. …
File Format / SizePDF / 237 Kb
Data Sheet. ADCMP380. SPECIFICATIONS. Table 2. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet ADCMP380 SPECIFICATIONS Table 2 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
VCC = 2 V to 5.5 V, VIN < VCC + 0.3 V, TA = −40°C to +85°C, unless otherwise noted. Typical values are at TA = 25°C.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
OPERATING VOLTAGE RANGE VCC 2 5.5 V Guarantees valid OUT output 0.9 V Guarantees OUT low UNDERVOLTAGE LOCKOUT (UVLO) Input Voltage Rising UVLORISE 1.95 V Input Voltage Falling UVLOFALL 1.65 V Hysteresis UVLOHYS 90 mV INPUT CURRENT VCC Quiescent Current ICC 92 190 nA OUT high 110 nA OUT high, TA = 25°C IN Average Input Current IVIN 4 8.5 nA VIN = 2 V, VCC = 5.5 V 4 32 nA VIN = 2 V, VCC = 2 V REFERENCE VOLTAGE VREF Input falling ADCMP380-1 0.984 1 1.016 V VREF = 1 V ADCMP380-2 0.489 0.5 0.511 V VREF = 0.5 V INPUT HYSTERESIS VHYST 10.3 mV PROPAGATION DELAY IN to OUT tPD 13.5 23 35 µs IN falling with VREF × 10% overdrive 22 39.5 61 µs IN rising with VREF × 10% overdrive IN GLITCH REJECTION tGR_IN 21 µs IN falling with VREF × 10% overdrive 38 µs IN rising with VREF × 10% overdrive OUT OUTPUT Output Voltage Low VOUT_OL 0.4 V VCC > 4.25 V, ISINK = 6.5 mA 0.4 V VCC > 2.5 V, ISINK = 6 mA 0.4 V VCC > 1.2 V, ISINK = 4.6 mA 0.4 V VCC > 0.9 V, ISINK = 0.9 mA Leakage Current 5 nA VOUT = VCC = 5.5 V EN INPUT VIL 0.4 V VIH 0.9 V EN Glitch Rejection 0.4 µs EN to OUT Delay tD_EN 0.65 µs EN falling EN Pull-Up Resistance 0.5 0.6 0.82 MΩ Rev. A | Page 3 of 10 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TRANSIENT IMMUNITY OUTPUT EN INPUT ADDING HYSTERESIS DEVICE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
