Datasheet ADCMP380 (Analog Devices) - 5
DescriptionUltralow Power Voltage Comparator with Reference
Pages / Page10 / 5 — Data Sheet. ADCMP380. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. BALL …
File Format / SizePDF / 237 Kb
Data Sheet. ADCMP380. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. BALL A1 INDICATOR. VCC. GND. OUT. TOP VIEW. (BALL SIDE DOWN)
Data Sheet ADCMP380 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS BALL A1 INDICATOR VCC GND OUT TOP VIEW (BALL SIDE DOWN)
Data Sheet ADCMP380 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS BALL A1 INDICATOR 1 2 VCC GND A EN GND B IN OUT C TOP VIEW
002
(BALL SIDE DOWN) Not to Scale
12783- Figure 2. Pin Configuration
Table 5. Pin Function Descriptions Pin No. Mnemonic Description
A1 VCC Power Supply Input. It is recommended to place a 0.1 µF decoupling capacitor between the VCC pin and the GND pin. A2 GND Ground. Both GND pins on the ADCMP380 must be grounded. B1 EN Active High Output Enable Input. If required, a 0.1 μF capacitor between the EN pin and ground provides additional noise immunity. B2 GND Ground. Both GND pins on the ADCMP380 must be grounded. C1 IN Comparator Input. C2 OUT Open-Drain Comparator Output. Rev. A | Page 5 of 10 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TRANSIENT IMMUNITY OUTPUT EN INPUT ADDING HYSTERESIS DEVICE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
