Datasheet ADCMP380 (Analog Devices) - 6
DescriptionUltralow Power Voltage Comparator with Reference
Pages / Page10 / 6 — ADCMP380. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 120. IVIN, VCC …
File Format / SizePDF / 237 Kb
ADCMP380. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 120. IVIN, VCC = 0V. 115. VIN, VCC = 2V. ICC, VCC = 2V. 110. 105. A) µ (. 100. A (n
ADCMP380 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 120 IVIN, VCC = 0V 115 VIN, VCC = 2V ICC, VCC = 2V 110 105 A) µ ( 100 A (n
ADCMP380 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 120 8 IVIN, VCC = 0V I 115 7 VIN, VCC = 2V ICC, VCC = 2V 110 6 105 5 A) µ ( 100 ) 4 NT A (n 95 3 I CC CURRE 90 2 UT 85 INP 1 80 0 75 –1 70 –2 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80
003
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5
006
TEMPERATURE (°C)
12783-
VIN (V)
12783- Figure 3. Supply Current (ICC) vs. Temperature Figure 6. Input Current for IN and VCC vs. VIN
3.0 0.50 RPULLUP = 10kΩ 0.45 RPULLUP = 100kΩ 2.5 0.40 VCC FALLING 0.35 2.0 E (V) G 0.30 A A) µ LT ( 1.5 O 0.25 I CC T V V U CC RISING 0.20 TP 1.0 OU 0.15 0.10 0.5 0.05 0 0 0 0.5 1.0 1.5 2.0 2.5
004
007
SUPPLY VOLTAGE (V) VOLTAGE ON V
12783-
CC (V)
12783- Figure 4. Supply Current (ICC) vs. Supply Voltage, VCC < 2 V Figure 7. Output Voltage vs. Voltage on VCC (with the OUT Pin Pulled up to the VCC Pin Through RPULLUP)
120 450 IN FALLING IN RISING 400 110 ) 350 s µ ( 100 300 TION A A) 250 n ( 90 DUR I CC 200 NT IE 80 150 RANS T 100 70 50 60 0 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5
005
1 10 100
008
SUPPLY VOLTAGE (V) OUT COMPARATOR OVERDRIVE (mV)
12783- 12783- Figure 5. Supply Current (I Figure 8. Maximum Transient Duration vs. OUT Comparator Overdrive CC) vs. Supply Voltage Rev. A | Page 6 of 10 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TRANSIENT IMMUNITY OUTPUT EN INPUT ADDING HYSTERESIS DEVICE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
