Datasheet HMC675LC3C (Analog Devices) - 9
Description10 GHz Latched Comparator with RSCML Output Stage
Pages / Page10 / 9 — HMC675LC3C. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. List of …
File Format / SizePDF / 569 Kb
HMC675LC3C. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. List of Materials for Evaluation PCB 125932 [1]
HMC675LC3C 10 GHz LATCHED COMPARATOR WITH RSCML OUTPUT STAGE List of Materials for Evaluation PCB 125932 [1]
HMC675LC3C
v10.0514
The circuit board used in the application should Item Description T use RF circuit design techniques. Signal lines J1 8 Pos. Vertical TIN M should have 50 ohm impedance while the pack- J2 - J7 2.92 mm 40 GHz Jack age ground leads should be connected directly to J8 Terminal Strip, Single Row 3 Pin SMT the ground plane similar to that shown. A sufficient JP1, JP2 2 Pos. Vertical TIN S - S number of via holes should be used to connect the C1 - C3, C5, C6, R 100 pF Capacitor, 0402 Pkg. top and bottom ground planes in order to provide C8 - C10 O good RF grounding to 25 GHz. The evaluation C4, C7, C11 330 pF Capacitor, 0402 Pkg. circuit board shown is available from Hittite upon AT C11 - C13 4.7 uF Tantalum request. R TP1 - TP4 DC Pin, Swage Mount A U1 HMC675LC3C Comparator P PCB 125929 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB OM [2] Circuit Board Material: Rogers 4350 or Arlon 25FR C
Application Circuit
I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
9
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
