Datasheet ADCMP572, ADCMP573 (Analog Devices) - 7
DescriptionUltrafast 3.3 V/5 V Single-Supply SiGe Comparators
Pages / Page14 / 7 — Data Sheet. ADCMP572/ADCMP573. TYPICAL PERFORMANCE CHARACTERISTICS. 39.0. …
RevisionB
File Format / SizePDF / 356 Kb
Data Sheet. ADCMP572/ADCMP573. TYPICAL PERFORMANCE CHARACTERISTICS. 39.0. 38.5. RROR (ps. 38.0. LAY. 37.5. 37.0. RISE/FALL TIME (ps)
Data Sheet ADCMP572/ADCMP573 TYPICAL PERFORMANCE CHARACTERISTICS 39.0 38.5 RROR (ps 38.0 LAY 37.5 37.0 RISE/FALL TIME (ps)
VCCI = VCCO = 3.3 V, TA = 25°C, unless otherwise noted.
20 39.0 ) 38.5 15 RROR (ps 38.0 E LAY 10 37.5 37.0 RISE/FALL TIME (ps) AGATION DE 5 OP R P 36.5 0 36.0 0 50 100 150 200 250 –60 –40 –20 0 20 40 60 80 100 INPUT OVERDRIVE VOLTAGE (mV)
04409-039
TEMPERATURE (°C)
04409-042 Figure 3. Propagation Delay vs. Input Overdrive Figure 6. Rise/Fall Time vs. Temperature
158.5 60 158.0 50 ) (ps 157.5 40 V) LAY m 157.0 ESIS ( 30 AGATION DE 156.5 YSTER H 20 OP R P 156.0 10 155.5 0 0 0.2 0.4 0.6 0.8 1.0 1.2 0 1 2 3 4 5 6 INPUT COMMON-MODE VOLTAGE (V)
04409-040
RHYS (k )
04409-043 Figure 4. Propagation Delay vs. Input Common-Mode Figure 7. Hysteresis vs. RHYS Control Resistor
160 80 158 70 s) p 60 156 V) m 50 154 ESIS ( 40 152 YSTER 30 H 150 PROPAGATION DELAY ( 20 148 10 146 0
04409-047
–60 –40 –20 0 20 40 60 80 100 –600 –500 –400 –300 –200 –100 0 R TEMPERATURE (°C) HYS SINK CURRENT (
A)
04409-041 Figure 5. Propagation Delay vs. Temperature Figure 8. Hysteresis vs. RHYS Sink Current Rev. B | Page 7 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING CML/RSPECL OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATIONDELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENTS TYPICAL APPLICATION CIRCUITS TIMING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
