Datasheet RH137 (Analog Devices) - 2
Description | Negative Adjustable Regulator |
Pages / Page | 4 / 2 — TABLE 1. ELECTRICAL CHARACTERISTICS. (Preirradiation) (Note 1). TA = … |
Revision | D |
File Format / Size | PDF / 635 Kb |
TABLE 1. ELECTRICAL CHARACTERISTICS. (Preirradiation) (Note 1). TA = 25°C. SUB-. –55°C ≤ TA ≤ 150°C. SYMBOL PARAMETER. CONDITIONS
RH137
TABLE 1. ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 1) TA = 25°C SUB- –55°C ≤ TA ≤ 150°C SUB- SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX GROUP MIN TYP MAX GROUP UNITS
VREF Reference Voltage |VIN – VOUT| = 5V, IOUT = 10mA –1.225 –1.275 1 V 3V ≤ |VIN – VOUT| ≤ 30V, –1.200 –1.300 1 –1.200 –1.300 2, 3 V 10mA ≤ IOUT ≤ IMAX, P ≤ PMAX ∆VOUT Line Regulation 3V ≤ |VIN – VOUT| ≤ 30V 2 0.02 1 0.05 2, 3 %/V ∆VIN ∆VOUT Load Regulation 10mA ≤ IOUT ≤ IMAX, |VOUT| ≤ 5V 2 25 1 50 2, 3 mV 10mA ≤ I 2 0.5 1 1 2, 3 % ∆IOUT OUT ≤ IMAX, |VOUT| ≥ 5V Thermal Regulation 10ms Pulse 0.02 1 %/W Ripple Rejection VOUT = –10V, f = 120Hz, CADJ = 0 60 dB VOUT = –10V, f = 120Hz, CADJ = 10µF 3 66 66 dB IADJ Adjust Pin Current 100 1 100 2, 3 µA ∆IADJ Adjust Pin Current 10mA ≤ IOUT ≤ IMAX 5 1 5 2, 3 µA Change 3V ≤ |VIN – VOUT| ≤ 30V 5 1 5 2, 3 µA IMIN Minimum Load |VIN – VOUT| = 30V 5 1 5 2, 3 mA Current |VIN – VOUT| ≤ 10V 3 1 3 2, 3 mA Current Limit |VIN – VOUT| ≤ 15V H Package 5 0.5 1 0.5 2, 3 A K Package 5 1.5 1 1.5 2, 3 A |VIN – VOUT| = 30V H Package 5 0.15 1 A K Package 5 0.24 1 A ∆VOUT Temperature Stability –55°C ≤ TJ ≤ 125°C 3 0.6 % ∆Temp ∆VOUT Long Term Stability TA = 125°C 3 1 % ∆Time en RMS Output Noise 10Hz ≤ f ≤ 10kHz 0.003 % θJC Thermal Resistance H Package 3 15 °C/W (Junction to Case) K Package 3 3 °C/W
TABLE 1A. ELECTRICAL CHARACTERISTICS (Postirradiation) (Note 4) 10KRAD(Si) 20KRAD(Si) 50KRAD(Si) 100KRAD(Si) 200KRAD(Si) SYMBOL PARAMETER CONDITIONS NOTES MIN MAX MIN MAX MIN MAX MIN MAX MIN MAX UNITS
VREF Reference |VIN – VOUT| ≤ 5V, IOUT = 10mA –1.225 –1.275 –1.225 –1.275 –1.225 –1.275 –1.225 –1.275 –1.22 –1.28 V Voltage 3V ≤ |VIN – VOUT| ≤ 30V, –1.2 –1.3 –1.2 –1.3 –1.2 –1.3 –1.2 –1.3 –1.2 –1.3 V 10mA ≤ IOUT ≤ IMAX, P ≤ PMAX ∆V Line 3V ≤ |V OUT IN – VOUT| ≤ 30V 2 0.02 0.02 0.02 0.02 0.02 %/V Regulation ∆VIN ∆V Load 10mA ≤ I OUT OUT ≤ IMAX, |VOUT| ≤ 5V 2 25 25 25 25 25 mV Regulation 10mA ≤ I ∆IOUT OUT ≤ IMAX, |VOUT| ≥ 5V 2 0.5 0.5 0.5 0.5 0.5 % Rev. D 2 For more information www.analog.com Document Outline Description Burn-In Circuit Absolute Maximum Ratings Package/Order Information Table 1. Electrical Characteristics Table 1A. Electrical Characteristics Table 2. Electrical Test Requirements Total Dose Bias Circuit Typical Application Typical Performance Characteristics
