Datasheet UF4001, UF4002, UF4003, UF4004, UF4005, UF4006, UF4007 (Vishay)
ManufacturerVishay
DescriptionUltrafast Plastic Rectifier
Pages / Page5 / 1 — FEATURES. TYPICAL APPLICATIONS. PRIMARY CHARACTERISTICS. MECHANICAL DATA. …
File Format / SizePDF / 73 Kb
FEATURES. TYPICAL APPLICATIONS. PRIMARY CHARACTERISTICS. MECHANICAL DATA. MAXIMUM RATINGS
Datasheet UF4001, UF4002, UF4003, UF4004, UF4005, UF4006, UF4007 Vishay
UF4001, UF4002, UF4003, UF4004, UF4005, UF4006, UF4007 www.vishay.com Vishay General Semiconductor Ultrafast Plastic Rectifier
FEATURES
• Glass passivated chip junction • Ultrafast reverse recovery time • Low forward voltage drop • Low switching losses, high efficiency DO-41 (DO-204AL) • High forward surge capability • Solder dip 275 °C max. 10 s, per JESD 22-B106 • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
For use in high frequency rectification and freewheeling application in switching mode converters and inverters for
consumer, computer, and telecommunication. IF(AV) 1.0 A 50 V, 100 V, 200 V, 400 V, 600 V, VRRM 800 V, 1000 V
MECHANICAL DATA
IFSM 30 A Case: DO-41 (DO-204AL) trr 50 ns, 75 ns Molding compound meets UL 94 V-0 flammability rating VF 1.0 V, 1.7 V Base P/N-E3 - RoHS-compliant, commercial grade T Base P/N-M3 - halogen-free, RoHS-compliant, commercial J max. 150 °C grade Package DO-41 (DO-204AL) Circuit configuration Single Terminals: matte tin plated leads, solderable per J-STD-002 and JESD 22-B102 E3 and M3 suffix meets JESD 201 class 1A whisker test Polarity: color band denotes cathode end
MAXIMUM RATINGS
(TA = 25 °C unless otherwise noted) PARAMETER SYMBOL UF4001 UF4002 UF4003 UF4004 UF4005 UF4006 UF4007 UNIT Maximum repetitive peak V reverse voltage RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current I 0.375" (9.5 mm) lead length at T F(AV) 1.0 A A = 55 °C Peak forward surge current 8.3 ms single half I sine-wave superimposed on rated load FSM 30 A Operating junction and storage temperature range TJ, TSTG -55 to +150 °C Revision: 06-Apr-2020 1 Document Number: 88755 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
