Datasheet LTC6226, LTC6227 (Analog Devices) - 2
Description | 1nV/√Hz 420MHz GBW, 180V/µs, Low Distortion Rail-to-Rail Output Op Amps |
Pages / Page | 28 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION |
File Format / Size | PDF / 2.3 Mb |
LTC6226/LTC6227
Total Supply Voltage (V– to V+) ...12V Output Current (Note 3) ...±100mA Input Voltage (–IN, +IN, SHDN)..V– – 0.3V to V+ + 0.3V Output Short-Circuit Duration ...Thermally Limited Input Current (–IN, +IN, SHDN) (Note 2) .. ±10mA Storage Temperature Range .. –65°C to 125°C Operating Temperature Range Maximum Junction Temperature .. 150°C LTC6226I/LTC6227I (Note 4) ...–40°C to 85°C MSOP Lead Temperature (Soldering 10s) ...300°C LTC6226H/LTC6227H (Note 4) .. –40°C to 125°C Specified Temperature Range LTC6226I/LTC6227I (Note 4) ...–40°C to 85°C LTC6226H/LTC6227H (Note 4) .. –40°C to 125°C
PIN CONFIGURATION
TOP VIEW TOP VIEW FB 1 8 SHDN OUT 1 6 V+ –IN 2 7 V+ – V– 2 5 SHDN + – +IN 3 + 6 OUT +IN 3 4 –IN V– 4 5 V– S6 PACKAGE S8 PACKAGE 6-LEAD PLASTIC TSOT-23 8-LEAD PLASTIC SO TJMAX = 150°C, θJA = 192°C/W (NOTE 8) TJMAX = 150°C, θJA = 120°C/W (NOTE 8) TOP VIEW TOP VIEW V+ 1 6 OUT OUTA 1 8 V+ +IN 7 2 5 –IN –INA 2 – 7 OUTB V– +INA 3 + 9 – 6 –INB + V– 3 4 SHDN V– 4 V– 5 +INB MSE PACKAGE DC PACKAGE 8-LEAD PLASTIC MSOP 6-LEAD (2mm × 2mm) PLASTIC DFN TJMAX = 150°C, θJA = 35°C/W (NOTE 8) T EXPOSED PAD (PIN 9) IS V–, MUST BE SOLDERED TO PCB JMAX = 150°C, θJA = 80°C/W (NOTE 8) EXPOSED PAD (PIN 7) IS V–, MUST BE SOLDERED TO PCB TOP VIEW OUTA 1 10 V+ –INA 2 9 OUTB 11 +INA 3 V– 8 –INB V– 4 7 +INB SHDNA 5 6 SHDNB DD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 125°C, θJA = 43°C/W (NOTE 8) EXPOSED PAD (PIN 11) IS V–, MUST BE SOLDERED TO PCB Rev 0 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
