Datasheet LTC6226, LTC6227 (Analog Devices) - 3
Description1nV/√Hz 420MHz GBW, 180V/µs, Low Distortion Rail-to-Rail Output Op Amps
Pages / Page28 / 3 — ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING. PACKAGE …
File Format / SizePDF / 2.3 Mb
ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING. PACKAGE DESCRIPTION. TEMPERATURE RANGE
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 LTC6226/LTC6227
LTC6226IS6#TRMPBF LTC6226IS6#TRPBF LTHGY 6-Lead TSOT-23 –40°C to 85°C LTC6226HS6#TRMPBF LTC6226HS6#TRPBF LTHGY 6-Lead TSOT-23 –40ºC to 125°C LTC6226IDC#TRMPBF LTC6226IDC#TRPBF LHGZ 6-Lead 2mm × 2mm DFN –40°C to 85°C LTC6226HDC#TRMPBF LTC6226HDC#TRPBF LHGZ 6-Lead 2mm × 2mm DFN –40ºC to 125°C LTC6226IS8#PBF LTC6226IS8#TRPBF 6226 8-Lead SOIC-8 –40°C to 85°C LTC6226HS8#PBF LTC6226HS8#TRPBF 6226 8-Lead SOIC-8 –40ºC to 125°C LTC6227IMS8E#PBF LTC6227IMS8E#TRPBF LTHHB 8-Lead MSOP, Exposed Pad –40°C to 85°C LTC6227HMS8E#PBF LTC6227HMS8E#TRPBF LTHHB 8-Lead MSOP, Exposed Pad –40ºC to 125°C LTC6227IDD#PBF LTC6227IDD#TRPBF LHHC 10-Lead 3mm × 3mm DFN –40°C to 85°C LTC6227HDD#PBF LTC6227HDD#TRPBF LHHC 10-Lead 3mm × 3mm DFN –40ºC to 125°C Contact the factory for parts specified with wider operating temperature ranges. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
ELECTRICAL CHARACTERISTICS (V The
denotes the specifications which apply over the S = ±5V) full operating temperature range, otherwise specifications are at TA = 25°C. VS = ±5V,VCM = 0V, VSHDN = floating unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage –95 20 95 μV l –225 225 μV ΔVOS Input Offset Voltage Match (Channel to –140 18 140 μV Channel, LTC6227, Note 5) l –400 400 μV TCVOS Input Offset Voltage Drift l 0.4 μV/°C IB Input Bias Current (Note 6) –20 –8.4 μA l –25 μA ΔIB Input Bias Current Match –2 0.3 2 µA (Channel to Channel,LTC6227, Note 5) l –3 3 µA IOS Input Offset Current –0.35 0.2 0.35 μA l –0.5 0.5 µA ΔIOS Input OffsetCurrent Match –0.7 0.15 0.7 µA (Channel to Channel, LTC6227, Note 5) l –1 1 µA en Input Noise Voltage Spectral Density f = 1MHz 1 nV/√Hz Integrated 1/f Noise 0.1Hz to 10Hz 0.77 μVP-P in Input Noise Current Spectral Density f = 1MHz 2.4 pA/√Hz CIN Input Capacitance Differential Mode 3 pF Common Mode 1 pF RIN Input Resistance Differential Mode 4.7 kΩ Common Mode 6 MΩ AVOL Large Signal Voltage Gain RL = 1kΩ to Half Supply VOUT = ±4V 114 139 dB l 110 dB RL = 100Ω to Half Supply VOUT = ±2.5V 93 110 dB l 88 dB CMRR Common Mode Rejection Ratio VCM = V– – 0.1V to V+ – 1.2V 100 114 dB l 95 dB VCMR Input Common Mode Range (Note 10) l V–– 0.1 V+ – 1.2 V PSRR+ Positive Power Supply Rejection Ratio V– = –1V, V+ = 1.8V to 10.75V 100 115 dB l 95 dB Rev 0 For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
