Datasheet AD8397 (Analog Devices) - 7
DescriptionRail-to-Rail, High Output Current Amplifier
Pages / Page16 / 7 — Data Sheet. AD8397. ABSOLUTE MAXIMUM RATINGS. MAXIMUM POWER DISSIPATION. …
File Format / SizePDF / 307 Kb
Data Sheet. AD8397. ABSOLUTE MAXIMUM RATINGS. MAXIMUM POWER DISSIPATION. Table 5. Parameter Rating. 4.5. J = 150°C. 4.0. 3.5. IO T A. 3.0. ISS
Data Sheet AD8397 ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Table 5 Parameter Rating 4.5 J = 150°C 4.0 3.5 IO T A 3.0 ISS
link to page 7
Data Sheet AD8397 ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Table 5.
The maximum power that can be dissipated safely by the AD8397
Parameter Rating
is limited by the associated rise in junction temperature. The Supply Voltage 26.4 V maximum safe junction temperature for plastic encapsulated Power Dissipation1 See Figure 4 devices is determined by the glass transition temperature of the Storage Temperature Range −65°C to +125°C plastic, approximately 150°C. Temporarily exceeding this limit Operating Temperature Range −40°C to +85°C may cause a shift in parametric performance due to a change in Lead Temperature (Soldering, 10 sec) 300°C the stresses exerted on the die by the package. Junction Temperature 150°C
4.5
1
T
Thermal resistance for standard JEDEC 4-layer board:
J = 150°C 4.0
8-lead SOIC_N: θJA = 157.6°C/W
8-Lead SOIC_N_EP: θ
W
JA = 47.2°C/W
( 3.5 N
Stresses at or above those listed under Absolute Maximum
IO T A 3.0
Ratings may cause permanent damage to the product. This is a
IP
stress rating only; functional operation of the product at these
ISS 2.5 D R
or any other conditions above those indicated in the operational
E 2.0 W
section of this specification is not implied. Operation beyond
O 1.5 M P
the maximum operating conditions for extended periods may
MU 8-LEAD SOIC
affect product reliability.
1.0 XI MA 0.5
0 02 9- 06
0
05
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 AMBIENT TEMPERATURE (°C)
Figure 4. Maximum Power Dissipation vs. Ambient Temperature
ESD CAUTION
Rev. B | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER SUPPLY AND DECOUPLING LAYOUT CONSIDERATIONS UNITY-GAIN OUTPUT SWING CAPACITIVE LOAD DRIVE OUTLINE DIMENSIONS ORDERING GUIDE
