Datasheet AD8510, AD8512, AD8513 (Analog Devices) - 8
Description | Precision, Very Low Noise, Low Input Bias Current, Wide Bandwidth JFET Quad Operational Amplifier |
Pages / Page | 21 / 8 — AD8510/AD8512/AD8513. Date Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. … |
Revision | K |
File Format / Size | PDF / 383 Kb |
AD8510/AD8512/AD8513. Date Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 120. 100k. VSY = ±15V. VSY = ±5V, ±15V. TA = 25°C. 100. 10k. A) p
AD8510/AD8512/AD8513 Date Sheet TYPICAL PERFORMANCE CHARACTERISTICS 120 100k VSY = ±15V VSY = ±5V, ±15V TA = 25°C 100 S 10k R A) p 80 ( LIFIE NT P M 1k A F 60 CURRE R O AS BE 100 40 BI UT NUM INP 20 10
007 010
0
02729- 02729-
–0.5 –0.4 –0.3 –0.2 –0.1 0 0.1 0.2 0.3 0.4 0.5 1 –40 –25 –10 5 20 35 50 65 80 95 110 125 INPUT OFFSET VOLTAGE (mV) TEMPERATURE (°C)
Figure 7. Input Offset Voltage Distribution Figure 10. Input Bias Current vs. Temperature
30 1000 VSY = ±15V B GRADE 25 S A) p R 100 ( 20 NT LIFIE ±15V P M A F 15 CURRE T 10 E R O S F ±5V BE F 10 O NUM UT 1 5 INP
1 008 1 0
0
02729-
0.1
02729-
0 1 2 3 4 5 6 –40 –25 –10 5 20 35 50 65 80 95 110 125 TCVOS (µV/°C) TEMPERATURE (°C)
Figure 8. AD8510/AD8512 TCVOS Distribution Figure 11. Input Offset Current vs. Temperature
30 40 VSY = ±15V TA = 25°C A GRADE 35 25 S 30 R A) p 20 ( 25 LIFIE NT P M A 20 F 15 CURRE R O AS 15 BE 10 BI UT NUM 10 INP 5 5
009 012
0
02729-
0
02729-
8 13 18 23 28 30 0 1 2 3 4 5 6 T SUPPLY VOLTAGE (V+ – V– ) CVOS (µV/°C)
Figure 9. AD8510/AD8512 TCVOS Distribution Figure 12. Input Bias Current vs. Supply Voltage Rev. K | Page 8 of 21 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS GENERAL APPLICATION INFORMATION INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL TOTAL HARMONIC DISTORTION (THD) + NOISE TOTAL NOISE INCLUDING SOURCE RESISTORS SETTLING TIME OVERLOAD RECOVERY TIME CAPACITIVE LOAD DRIVE OPEN-LOOP GAIN AND PHASE RESPONSE PRECISION RECTIFIERS I-V CONVERSION APPLICATIONS Photodiode Circuits Signal Transmission Applications Crosstalk OUTLINE DIMENSIONS ORDERING GUIDE
