Datasheet AD8023 (Analog Devices) - 2
Description | High Current Output, Triple Video Amplifier |
Pages / Page | 11 / 2 — AD8023–SPECIFICATIONS (@ TA = +25. C, VS =. 7.5, CLOAD = 10 pF, RLOAD = … |
Revision | A |
File Format / Size | PDF / 567 Kb |
AD8023–SPECIFICATIONS (@ TA = +25. C, VS =. 7.5, CLOAD = 10 pF, RLOAD = 150. , unless otherwise noted) Model. AD8023A. Conditions
AD8023–SPECIFICATIONS (@ TA = +25 C, VS = 7.5, CLOAD = 10 pF, RLOAD = 150 , unless otherwise noted) Model AD8023A Conditions VS Min Typ Max Units
DYNAMIC PERFORMANCE Bandwidth (3 dB) RFB = 750 Ω No Peaking, G = +3 125 MHz Bandwidth (0.1 dB) No Peaking, G = +3 7 MHz Slew Rate 5 V Step 1200 V/µs Settling Time to 0.1% 0 V to ± 6 V (6 V Step) CLOAD = 300 pF RLOAD > 1 kΩ, RFB = 750 Ω TA = +25°C to +70°C, RS = 16.9 Ω 30 ns NOISE/HARMONIC PERFORMANCE Total Harmonic Distortion fC = 5 MHz, RL = 150 Ω, VO = 2 p-p –72 dBc Input Voltage Noise f = 10 kHz 2.0 nV/√Hz Input Current Noise f = 10 kHz (–IIN) 14 pA/√Hz Differential Gain (RL = 150 Ω) f = 3.58 MHz, G = +2, RFB = 750 Ω 0.06 % Differential Phase (RL = 150 Ω) f = 3.58 MHz, G = +2, RFB = 750 Ω 0.02 Degrees DC PERFORMANCE Input Offset Voltage TMIN to TMAX –5 2 5 mV Offset Drift 2 µV/°C Input Bias Current (–) TMIN to TMAX –45 15 45 µA Input Bias Current (+) TMIN to TMAX –25 5 25 µA Open-Loop Transresistance 67 111 kΩ TMIN to TMAX 50 111 kΩ INPUT CHARACTERISTICS Input Resistance +Input TMIN to TMAX 100 kΩ –Input TMIN to TMAX 75 Ω Input Capacitance 2 pF Input Common-Mode Voltage Range ±6.0 V Common-Mode Rejection Ratio Input Offset Voltage 50 56 dB –Input Current 0.2 µA/V +Input Current 5 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing RL = 1 kΩ VOL–VEE 0.8 1.0 V VCC–VOH 0.8 1.0 V RL = 150 Ω VOL–VEE 1.0 1.3 V VCC–VOH 1.0 1.3 V Output Current 50 70 mA Short-Circuit Current 300 mA Capacitive Load Drive 1000 pF MATCHING CHARACTERISTICS Dynamic Crosstalk G = +2, f = 5 MHz 70 dB DC Input Offset Voltage –5 0.3 5 mV –Input Bias Current –10 3 10 µA POWER SUPPLY Operating Range Single Supply +4.2 +15 V Dual Supply ±2.1 ±7.5 V Quiescent Current/Amplifier 6.2 mA 7.0 10.0 mA TMIN to TMAX Power-Down 1.3 4.0 mA –2– REV. A
