Datasheet OP467 (Analog Devices) - 7
DescriptionQuad Precision, High Speed Operational Amplifier
Pages / Page20 / 7 — OP467. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VS = ±15V. A = 25°C. RL …
RevisionI
File Format / SizePDF / 493 Kb
OP467. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VS = ±15V. A = 25°C. RL = 1MΩ. L = 30pF. AVCL = +100. GAIN. rees. P G. DANC E. –90. PHASE. SE S
OP467 TYPICAL PERFORMANCE CHARACTERISTICS 100 VS = ±15V A = 25°C RL = 1MΩ L = 30pF AVCL = +100 GAIN rees P G DANC E –90 PHASE SE S
OP467 TYPICAL PERFORMANCE CHARACTERISTICS 100 80 VS = ±15V VS = ±15V T 70 A = 25°C RL = 1MΩ C 80 60 L = 30pF ) ) B 50 ) AVCL = +100 (d GAIN rees (Ω 60 IN 40 eg E A (D P G 30 T O IF DANC E O H P 40 -L 20 –90 N PHASE IM A E SE S VCL = +10 P 10 –135 A O PH 20 0 –180
9
–10
6 00
AVCL = +1
00 2- 2- 30 30
0
00
–20
00
100 1k 10k 100k 1M 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 6. Open-Loop Gain, Phase vs. Frequency Figure 9. Closed-Loop Output Impedance vs. Frequency
80 VS = ±15V TA = 25°C 60 0.3 ) VS = ±5V B d 0.2 ( B) IN (d 40 0.1 R GA 0.0 RRO OOP E VS = ±15V -L IN –0.1 D 20 E A G OS –0.2 L C 0 –0.3
10 7 0 00 2- 2- 30 30
0
00
–20
00
3.4 5.8 100k 1M 10M 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 7. Closed-Loop Gain vs. Frequency Figure 10. Gain Error vs. Frequency
25 30 AVCL = –1 25 20 ) ) T (V V A = +125°C G AVCL = +1 /m IN V 20 ( W 15 IN S T U GA P 15 T T U OOP A = +25°C 10 -L M O N 10 E TA = –55°C IMU OP X 5 MA V 5 S = ±15V T
8
A = 25°C
11 00 0
R
2-
L = 2kΩ
2- 30 030 00
0 0
0
0 ±5 ±10 ±15 ±20 1k 10k 100k 1M 10M SUPPLY VOLTAGE (V) FREQUENCY (Hz)
Figure 8. Open-Loop Gain vs. Supply Voltage Figure 11. Maximum VOUT Swing vs. Frequency Rev. * | Page 7 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE DICE CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT SHORT-CIRCUIT PERFORMANCE UNUSED AMPLIFIERS PCB LAYOUT CONSIDERATIONS GROUNDING POWER SUPPLY CONSIDERATIONS SIGNAL CONSIDERATIONS PHASE REVERSAL SATURATION RECOVERY TIME HIGH SPEED INSTRUMENTATION AMPLIFIER 2 MHz BIQUAD BAND-PASS FILTER FAST I-TO-V CONVERTER OP467 SPICE MARCO-MODEL OUTLINE DIMENSIONS ORDERING GUIDE
