Datasheet MAX4400, MAX4401, MAX4402, MAX4403 (Maxim) - 7
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
Pages / Page13 / 7 — Typical Operating Characteristics. GAIN AND PHASE. POWER-SUPPLY REJECTION …
Typical Operating Characteristics. GAIN AND PHASE. POWER-SUPPLY REJECTION RATIO. vs. FREQUENCY (NO LOAD)
Typical Operating Characteristics GAIN AND PHASE POWER-SUPPLY REJECTION RATIO vs FREQUENCY (NO LOAD)
MAX4400–MAX4403 Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
(VDD = +5V, VSS = 0V, VCM = VDD/2, VSHDN = 5V, RL = ∞ connected to VDD/2, TA = +25°C, unless otherwise noted.)
GAIN AND PHASE GAIN AND PHASE POWER-SUPPLY REJECTION RATIO vs. FREQUENCY (NO LOAD) vs. FREQUENCY (CL = 400pF) vs. FREQUENCY
80 80 10 60 60 40 MAX4400 toc01 40 MAX4400 toc02 -10 MAX4400 toc03 20 20 0 0 -30 -20 -20 -40 -40 -50 -60 -60 PSRR (dB) -80 -80 -70 -100 -100 GAIN (dB)/PHASE (degrees) -120 GAIN (dB)/PHASE (degrees) -120 -90 -140 -140 -160 -160 AVCL = +1000V/V AVCL = +1000V/V -180 -180 -110 1 10 100 1k 10k 100k 1M 10M 1 10 100 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
MAX4401 OUTPUT IMPEDANCE SUPPLY CURRENT SHUTDOWN SUPPLY CURRENT vs. FREQUENCY vs. TEMPERATURE vs. TEMPERATURE
1000 500 100k VSHDN = VSS 100 MAX4400 toc4 MAX4400 toc05 ) 10k MAX4400 toc06 Ω 450 µA) 10 1k 1 400 100 0.1 SUPPLY CURRENT ( SUPPLY CURRENT (pA) OUTPUT IMPEDANCE ( 350 10 0.01 0.001 300 1 10 100 1k 10k 100k 1M -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 FREQUENCY (Hz) TEMPERATURE (°C) TEMPERATURE (°C)
MAX4401 OUTPUT LEAKAGE CURRENT INPUT OFFSET VOLTAGE OUTPUT VOLTAGE SWING HIGH vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
1M 1500 70 VSHDN = VSS RL = 2kΩ to VDD/2 VOUT = VDD/2 60 1000 MAX4400 toc07 MAX4400 toc08 MAX4400 toc09 50 1k 500 (mV) 40 (pA) (µV) OH 0 - V I LEAK V OS 30 V DD 10 -500 20 -1000 10 0 0.1 -1500 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) www.maximintegrated.com Maxim Integrated │ 7
