Low-Cost, Low-Power, Low-Dropout,SOT23-3 Voltage ReferencesMAX6001–MAX6005ELECTRICAL CHARACTERISTICS—MAX6002 (VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETERSYMBOLCONDITIONSMINTYPMAXUNITSOUTPUT Output Voltage VOUT TA = +25°C 2.475 2.500 2.525 V Output Voltage Temperature TCVOUT 20 100 ppm/°C Coefficient (Note 2) ∆VOUT/ Line Regulation ∆ (VOUT + 0.2V) ≤ VIN ≤ 12.6V 15 200 µV/V VIN ∆VOUT/ Sourcing: 0 ≤ IOUT ≤ 400µA 0.14 0.90 Load Regulation ∆ µV/µA IOUT Sinking: -400µA ≤ IOUT ≤ 0 0.18 1.10 Dropout Voltage VIN - IOUT = 400µA 100 200 mV (Note 5) VOUT Short to GND 4 OUT Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis ∆VOUT/ 130 ppm (Note 3) time ∆VOUT/ ppm/ Long-Term Stability 1,000 hours at TA = +25°C 50 time 1,000hrs DYNAMIC f = 0.1Hz to 10Hz 60 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 125 µVRMS ∆VOUT/ Ripple Rejection ∆ VIN = 5V ±100mV, f = 120Hz 82 dB VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 85 µs Capacitive-Load Stability Range COUT (Note 4) 0 2.2 nF INPUT Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 27 45 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 0.8 2.6 µA/V _______________________________________________________________________________________3
