Datasheet 1ED34x1Mc12M (1ED-X3 Analog) (Infineon) - 6
Manufacturer | Infineon |
Description | EiceDRIVER/ 1ED34x1Mc12M Enhanced. Single-channel isolated gate driver IC with adjustable DESAT and soft-off |
Pages / Page | 45 / 6 — EiceDRIVER™ 1ED34x1Mc12M Enhanced. Datasheet. 2 Related products. Related … |
Revision | 02_00 |
File Format / Size | PDF / 733 Kb |
EiceDRIVER™ 1ED34x1Mc12M Enhanced. Datasheet. 2 Related products. Related products. Product group. Product name. Description
EiceDRIVER™ 1ED34x1Mc12M Enhanced Datasheet 2 Related products 2 Related products Product group Product name Description
TRENCHSTOP™
IKQ75N120CS6
High Speed 1200 V, 75 A IGBT with anti-parallel diode in TO247-3 IGBT Discrete
IKW15N120BH6
High Speed 1200 V, 15 A IGBT with anti-parallel diode in TO247
IHW40N120R5
Reverse conducting 1200 V, 40 A IH IGBT with integrated diode in TO247 CoolSiC™ SiC
IMW120R045M1
1200 V, 45 mΩ SiC MOSFET in TO247-3 package MOSFET Discrete
IMZ120R350M1H
1200 V, 350 mΩ SiC MOSFET in TO247-4 package
IMZA65R027M1H
650 V, 27 mΩ SiC MOSFET in TO247-4 package
IMW65R107M1H
650 V, 107 mΩ SiC MOSFET in TO247-3 package CoolSiC™ SiC
FS45MR12W1M1_B11
EasyPACK™ 1B 1200 V / 45 mΩ sixpack module MOSFET Module
FF6MR12W2M1_B11
EasyDUAL™ 2B 1200 V, 6 mΩ halfbridge module
FF6MR12W2M1_B11
EasyPACK™ 2B 1200 V, 11 mΩ 3-Level module in Advanced NPC (ANPC) topology
F4-23MR12W1M1_B11
EasyPACK™ 1B 1200 V, 23 mΩ fourpack module TRENCHSTOP™
FP10R12W1T7_B11
EasyPIM™ 1B 1200 V, 10 A three phase input rectifier PIM IGBT IGBT Modules module
FS100R12W2T7_B11
EasyPACK™ 2B 1200 V, 100 A sixpack IGBT module
FP150R12KT4_B11
EconoPIM™ 3 1200V three phase PIM IGBT module
FS200R12KT4R_B11
EconoPACK™ 3 1200 V, 200 A sixpack IGBT module Datasheet 6 v2.0 2020-03-26 Document Outline Table of contents 1 Block diagram 2 Related products 3 Pin configuration and functionality 3.1 Pin configuration 3.2 Pin functionality 4 Functional description 4.1 Start-up and fault clearing 4.2 Supply 4.2.1 Input side undervoltage lockout, VCC1 UVLO 4.2.2 Output side under-voltage lockout, VCC2 UVLO 4.3 Input side logic 4.3.1 IN non-inverting driver input 4.3.2 RDYC ready status output, fault-off and fault clear input 4.3.2.1 RDYC fault-off input 4.3.2.2 RDYC fault clear input 4.3.3 FLT_N status output and fault-off input 4.3.3.1 FLT_N fault-off input 4.4 Desaturation protection 4.4.1 DESAT behavior 4.4.2 DESAT filter and leading edge blanking time adjustment with ADJB 4.5 Gate driver output 4.5.1 Turn-on behavior 4.5.2 Turn-off and fault turn-off behavior 4.5.2.1 Hard switching turn-off 4.5.2.2 Soft turn-off 4.5.2.2.1 Soft-off current source adjustment with ADJA 4.5.3 Active shut-down 4.5.4 Active Miller clamp 4.5.4.1 CLAMP output types 4.5.5 Switch-off timeout until forced switch-off 4.6 Short circuit clamping 5 Electrical parameters 5.1 Absolute maximum ratings 5.2 Thermal parameters 5.3 Operating parameters 5.4 Electrical characteristics 5.4.1 Voltage supply 5.4.2 Logic input and output 5.4.3 Analog input 5.4.4 Gate driver 5.4.5 Active Miller clamp 5.4.6 Dynamic characteristics 5.4.7 Desaturation protection 5.4.8 Soft-off current source 5.4.9 Over-temperature protection 6 Insulation characteristics 6.1 Certified according to VDE 0884-11 and IEC 60747-17 reinforced insulation (planned) 6.2 Recognized under UL 1577 (planned) 6.3 Reliability 7 Package information 8 Application notes 8.1 Reference layout for thermal data 8.2 Printed circuit board guidelines Revision history Disclaimer
