Datasheet TCKE712BNL (Toshiba) - 5
ManufacturerToshiba
Description13.2 V, eFuse with Adjustable Over Current Protection
Pages / Page15 / 5 — PIN Description. PIN Name. Description. Operation Logic Table. EN “Low”. …
File Format / SizePDF / 632 Kb
PIN Description. PIN Name. Description. Operation Logic Table. EN “Low”. EN “High”
PIN Description PIN Name Description Operation Logic Table EN “Low” EN “High”
TCKE712BNL
VIN Supply Input. Input to the power switch and the supply voltage for the device. Rise time set input. A capacitor between dV/dT terminal and GND set the slew rate of dV/dT VOUT. EN Enable input. ILIM Current limit set input. A resistor between ILIM terminal and GND set the current limit. GND Ground. Over voltage protection(OVP) threshold set input. The threshold voltage of the overvoltage OVP protection function is adjusted by the resistance value connected to the OVP terminal. FLAG Open drain signal output. Fault condition flag VOUT Output. Output of the power switch.
Output OFF
ON
© 2020 5 2020-12-14 Toshiba Electronic Devices & Storage Corporation
