Datasheet ADA4098-1 (Analog Devices) - 5
Description50 V, 1 MHz, 165 µA, Robust Over-The-Top Precision Op Amp
Pages / Page27 / 5 — Preliminary Technical Data. ADA4098-1. ±15 V SUPPLY. Table 2. B Grade. H …
RevisionPrA
Preliminary Technical Data. ADA4098-1. ±15 V SUPPLY. Table 2. B Grade. H Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Preliminary Technical Data ADA4098-1 ±15 V SUPPLY Table 2 B Grade H Grade Parameter Test Conditions/Comments Min Typ Max Unit
link to page 9 link to page 9
VCM = 0V, SHDN pin is open, RL = 499 kΩ to ground, and TA = 25°C, unless otherwise noted.
Table 2. B Grade H Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DC PERFORMANCE Offset Voltage (VOS)1 ±15 ±35 ±15 ±35 µV TMIN < TA < TMAX ±90 ±100 µV VSY = ±25 V ±15 ±35 ±15 ±35 µV TMIN < TA < TMAX ±90 ±100 µV Voltage Offset Drift2 TMIN < TA < TMAX ±0.1 ±0.5 ±0.1 ±0.8 µV/°C Input Bias Current ±0.35 ±0.7 ±0.35 ±0.7 nA TMIN < TA < TMAX ±10 ±25 nA VSY = ±25 V ±0.35 ±0.7 ±0.35 ±0.7 nA TMIN < TA < TMAX ±10 ±25 nA Input Offset Current ±0.35 ±0.7 ±0.35 ±0.7 nA TMIN < TA < TMAX ±5 ±15 nA VSY = ±25 V ±0.35 ±0.7 ±0.35 ±0.7 nA TMIN < TA < TMAX ±5 ±15 nA CMRR VCM = −14.75 V to +13.5 V 118 135 118 135 dB TMIN < TA < TMAX 116 116 dB VCM = −15.1 V to +13.5 V 117 135 117 135 dB TMIN < TA < TMAX 107 107 dB VCM = −15.1 V to +55 V 123 140 123 140 dB TMIN < TA < TMAX 116 116 dB Common-Mode Input Guaranteed by CMRR tests −15.1 +55 −15.1 +55 V Range AOL ΔVOUT = 25 V 134 150 134 150 dB TMIN < TA < TMAX 126 123 dB ΔVOUT = 25 V, RL =10 kΩ 117 120 117 120 dB TMIN < TA < TMAX 108 106 dB NOISE PERFORMANCE Input Voltage Noise f = 0.1 Hz to 10 Hz 400 400 nV p-p 1/f noise corner 6 6 Hz f = 100 Hz 18 18 nV/√Hz Over-The-Top f = 100 Hz, VCM > +VS 20 20 nV/√Hz Input Current Noise f =100 Hz 0.15 0.15 pA/√Hz Over-The-Top f = 100 Hz, VCM > +VS 1.8 1.8 pA/√Hz DYNAMIC PERFORMANCE Slew Rate ΔVOUT = 25 V 0.45 0.85 0.45 0.85 V/μs TMIN < TA < TMAX 0.2 0.2 V/μs GBP fTEST = 25 kHz 1 1.05 1 1.05 MHz TMIN < TA < TMAX 0.95 0.95 MHz Phase Margin 57 57 deg 1% Settling Time ΔVOUT = ±2 V TBD TBD μs 0.1% Settling Time ΔVOUT = ±2 V TBD TBD μs THD + N f = 10 kHz, VOUT = 5.6 V p-p, RL = 10 kΩ, TBD TBD % bandwidth = 80 kHz INPUT CHARACTERISTICS Input Resistance Differential mode 1 1 MΩ Common mode >1 >1 GΩ Over-The-Top Differential mode VCM > 5 V 7 7 kΩ Common mode VCM > 5 V >250 >250 MΩ Input Capacitance Differential mode 1 1 pF Common mode 3 3 pF Rev. PrA | Page 5 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS SPECIFICATIONS 5 V SUPPLY ±15 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT PROTECTION OVER-THE-TOP OPERATION CONSIDERATIONS OUTPUT SHUTDOWN PIN (SHDN) APPLICATIONS INFORMATION LARGE RESISTOR GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE DISTORTION POWER DISSIPATION AND THERMAL SHUTDOWN CIRCUIT LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING ESD PROTECTION WHEN POWERED RELATED PRODUCTS TYPICAL APPLICATIONS OUTLINE DIMENSIONS
