Datasheet ADA4500-2 (Analog Devices) - 8
Description10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifier
Pages / Page24 / 8 — ADA4500-2. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. OUT …
RevisionB
ADA4500-2. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. OUT A 1. 8 V+. –IN A 2. 7 OUT B. +IN A 3. TOP VIEW. 6 –IN B
ADA4500-2 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS OUT A 1 8 V+ –IN A 2 7 OUT B +IN A 3 TOP VIEW 6 –IN B
ADA4500-2 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS OUT A 1 8 V+ –IN A 2 7 OUT B ADA4500-2 OUT A 1 8 V+ +IN A 3 TOP VIEW 6 –IN B –IN A 2 7 OUT B (Not to Scale) ADA4500-2 5 +IN B TOP VIEW V– 4 +IN A 3 6 –IN B (Not to Scale)
0
NOTES
40 00 2
V– 4 5 +IN B
7-
1. CONNECT THE EXPOSED PAD TO V–
7- 61
OR LEAVE IT UNCONNECTED.
10 061 1 Figure 3. 8-Lead MSOP Pin Configuration Figure 4. 8-Lead LFCSP Pin Configuration
Table 5. 8-Lead MSOP and 8-Lead LFCSP Pin Function Descriptions Pin No. Mnemonic Description
1 OUT A Output, Channel A. 2 −IN A Inverting Input, Channel A. 3 +IN A Noninverting Input, Channel A. 4 V− Negative Supply Voltage. 5 +IN B Noninverting Input, Channel B. 6 −IN B Inverting Input, Channel B. 7 OUT B Output, Channel B. 8 V+ Positive Supply Voltage. EPAD For the LFCSP package only, connect the exposed pad to V− or leave it unconnected. Rev. B | Page 8 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VSY = 2.7 V ELECTRICAL CHARACTERISTICS VSY = 5.0 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL OUTPUT RAIL-TO-RAIL INPUT (RRI) ZERO CROSS-OVER DISTORTION OVERLOAD RECOVERY POWER-ON CURRENT PROFILE APPLICATIONS INFORMATION RESISTANCE AND CAPACITANCE SENSOR CIRCUIT ADAPTIVE SINGLE-ENDED-TO-DIFFERENTIAL SIGNAL CONVERTER The Challenge The Solution OUTLINE DIMENSIONS ORDERING GUIDE
